Freeware programs and applications
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
psiu
1,629
Another vote for Audiograbber.
EDIT: It's the freeware version of AudioCatalyst.
Uses FreeDB...plenty of options, including naming and directory organization.
I like it anyway...has a link to lame.dll site, I downloaded the torrent for that (per the request on the site) and it was done in seconds.
Another great thing with this software is that it does not put a single file in your windows directories! No DLL's, OCX's, device drivers, spyware, adware or whatever else that messes up the computer. Not a single entry in the registry or win.ini. If you delete the Audiograbber directory it's all gone, that's it!
Audiograbber used to be shareware but is from February 9, 2004 released as freeware! Get it from the download page.
Mo0o
24,227
Heres a great graphics editor. http://www.eecs.wsu.edu/paint.net/
It's free and a great MSPaint replacement. And it loads much quicker than Photoshop so if you just have to do a quick cropandchop this is much faster than waiting for everything to load on photoshop.
Nebben
706
Warez = illegally download copyrighted software
Where the term 'warez' came from, your guess is as good as mine.
Anyway, this thread is very nice.
cecallred
29
have any of you tried Servant Salamander for a dual paned file viewer? I've been using it for years now. Paid about 20 or 25 dollars for it and I'm still good on the updates. It has several plugins that add a lot of functionality and if you're curious.. try it here:
www.altap.cz
Cec
MrNutz
Banned
Oct 18, 2001
851
Awesome List. (BTW, WinSCP is based on PuTTy :p)
Great WinInstaller Packaging Program: Install Creator
Wonderful Utility to Save/Restore your desktop icon orientations: Desktop Restore
(Saves info in the registry and creates a quick command in the right-click menu)
imported_Torx
13
warez comes from the shortened version of softwares with the s changed to z to signify it's leetness.
Anyone know of a bootable cd or floppy than can access XP restore points and roll back to one? Ive used ERD Commander but I'd like something legal for work.
Retro2001
767
Filezilla should be listed in the SFTP/SCP section also, as it can connect via those protocals also.
Does anyone know of a framework (like Konfabulator) that would let me create a systemtray sensor that would popup notifications based on SQL queries?
Peace,
will
b4u
1,380
Hi,
Some more contributions ... :)
I recently found a site with lot's of free software. The site's named Pablo Software Solutions and the products available are:
ASP2VB
ASP to Visual Basic ActiveX DLL Converter
Baby FTP Server
Very small anonymous FTP server for beginners.
Baby POP3 Server
Simple but fully functional POP3 Server.
Baby ASP Web Server
Small Web Server with native support for ASP and SSL!
Cookie Viewer
Utility to view the cookies stored on your computer.
DBF Explorer
Utility for viewing and editing DBF files (dBase III).
FTP Wanderer
Freeware FTP Client with the look and feel of Windows Explorer.
Little Install Builder
Simple but powerfull freeware setup program builder.
MDB2XML
Converts a MS Access database (MDB) to a XML document.
Multi Ping
Ping multiple target at the same time and log the results.
Pablo Commander
Clone of Norton Commander with the look and feel of Windows Explorer.
File Management utility with integrated FTP Client.
POP3 Preview
Delete SPAM messages and Viruses before you download them.
Pablo?s Popup Killer
Kills those annoying popup windows while you are browsing the internet.
Quick ?n Easy FTP Server
Freeware, easy to use and powerfull FTP Server.
Quick ?n Easy FTP Service
FTP Server based on Quick ?n Easy FTP server that runs as a NT service.
Quick ?n Easy Web Service
A great alternative for Microsoft?s IIS ASP Web Server!
UpdateIP
Update the link to your (dynamic) IP address on your website via FTP.
Virtual Piano
Virtual Piano is a MIDI controller for Sound Cards or other MIDI devices.
Wave Editor
Simple wave editor.
WYSIWYG Web Builder
A What-You-See-Is-What-You-Get Website builder. No HTML knowlegde needed.
<edit>
Oh, and it also has some Source Code available, though I just took a 1 minute look over it ... it may be good for developers (myself included).
</edit>
A bunch of programs here, I haven't tested them all yet, but I plan to do so as I feel the need for it :)
Have a nice testing ... :)
MrRobercik
I would like to add XnViewXnView for image viewing. It has been a great ACDsee replacement. In my opinion it beats Irfan on GUI part.
Thank you for info on Alzip, it is actually faster than Izarc I have been using so far.
As far as e-mail client, I use Incredimail for quite some time now and like it a lot. You can use it for free, just cant use skin changer and letter creator until you pay for it.
zmaster
342
IDA thats Internet Download Accelerator. One of the few that supports firefox. Lets add Fire Fox to the list shall we?
Todd33
7,842
Freemat - Matlab like opensource program. It's a fast prototyping engineer program for calculations and plotting.
b4u
1,380
Hi,
I have a bunch of musics in MP3 format which I want to burn into an audio CD. For ease of use, I want to burn them all to a single CD, but all musics (their total, I mean) occupy 1Mb more than the CD capacity :(. Since it will be played on regular CD players, I don't think overburning would be an option (correct me if I'm wrong).
So, I'm thinking about choosing 1 or 2 MP3s, and scale down the quality a bit, so they fit all in a CD (as long as the loss of quality isn't noticeable).
Anyone can tell me if the MP3 editors in the list are capable of picking an MP3 and give me the choice of dropping quality a bit? If not, can you recommend some software that can do the trick?
Thanks.
MadRat
11,999
307
Audio CD's are measured in time, not MB. Perhaps you should try first to remove all dead spaces between the songs.
secondvijai007
14
There is a wonderful program called mp3mymp3, its free, and the fun thing about it is that it records any sound that goes through your sound card. Its actually quite useful, for recording sound from a radio show, or webcast.
Status
