- Jan 26, 2000
- 50,879
- 4,268
- 126
Let's assume you were in charge. You know where Bin Laden is, or you are fairly certain, enough to engage in an op.
This isn't a situation in a vacuum, so here are your constraints. You cannot move him by diplomatic means. You cannot force others to take action. Commitment to getting OBL alive will most likely result in failure. Bin Laden is a proven menace still connected to Al Qaeda and there is no reason that he's not actively involved planning terrorist attacks.
What do you do? Do you pretend he isn't there or do you take action? The ISI doesn't care about international opinion. He continues on as he has or he is eliminated by us. If you insist on live removal the team will most likely die and our failure worsens the situation incalculably.
What isn't relevant to this question:
US history- Bringing up past events. Don't even bother. It doesn't answer the question.
9/11- Revenge or justice or whatever you think it is doesn't matter. I am purposefully considering the threat that Bin Laden currently poses. "He deserved it" is also completely irrelevant.
Principles of conscience- You do not have that luxury of doing anything other than what you rationally consider best for the US, not soothing your ego.
You are faced with acting or not. Given the constraints the world places upon you, what do you do and how do you justify your actions to the American public, who you are answerable to?
Go.
Go.
