First FX-9590 benchmarks
Status
Not open for further replies.
I get more insulted when companies disable features on their "enthusiast" parts and then charge a premium for the privilege...
Regardless of the features you cannot say that you get tangible performance benefits for the extra money you pay. With AMD FX fanboy edition, you don't.
And how much slower than an i7 3930/60/70 is the FX-9590
x264 FHD:
29 fps - AMD FX-9690 @ 5,0GHz (4 C / 8T )
27.7 fps - Intel i7-3930K @ 3.2GHz ( 6C / 12T )
http://www.x264fhdbenchmark.republika.pl/Results.txt
Fritz chess
15 678 - AMD FX-9690 @ 5,0GHz (4 C / 8T )
14 139 - Intel i7-3690X @ 3.9GHz ( 6C / 12T )
GF process can endure slightly higher voltage than intels.
I expect this to be true because it is a 32nm SOI node compared to a 22nm finfet node, but is there any actual proof or evidence that supports this statement?
So far as I am aware, neither Intel nor AMD have published a max allowed Vcore for the respective products under discussion here.
My i5 is uses a $50 air cooler, I'm not sure what point you were attempting to make.
I was only alluding to the fact that this seems to simply be a factory overclocked 8350, nothing more.
Both the rumored 220w TDP and $1000 price tag are clearly jokes.
Yes because running a $1000 CPU on a $50 cooler makes alot of sense. Not everybody cares about TDP, especially not enthusiasts who spend that much money on parts. A heavily overclocked hex core SB-E would easily sit above 200W as well, so I don't see how this is a "joke".
No actual evidence, but users have been running 8150/8350s at well above 1.5v with no adverse effects. Some people bench them at 1.6v but that seems a little outrageous to me.
I am surprised about how many people care about energy efficiency for high end chips...
You should have been here in 2005, you couldn't get through ten posts without a pro-AMD member talking down how foolish it was to buy a Prescott P4 because the energy efficiency was so poor compared to their fancy SOI-based X2 chips.
The pro-Intel members would respond with something more or less identical to your post above.
What you see today in these forums is nothing new for those of us who've been around a while. The only thing new is that the shoe is now on the other foot now and it is the pro-AMD members who are now arguing that energy efficiency is a red herring.
ok, I'm still relatively new to cpus so I'll take your word for it.
At 1.55V AMD has the chip in OPs link at voltages used by overclockers that don't mind taking chances or just cranking it up for validation runs. I'd say most FX x3xx series overclockers have stayed at or below 1.4V:
http://www.overclock.net/t/1318995/official-fx-8320-fx-8350-vishera-owners-club
Perhaps those people can take this as a sign that perhaps 32nm is as robust as 45nm was and experiment with 1.45V-1.5V everyday settings as people did with Phenom II.
As for efficiency I think people suggesting it's no big deal now are just as wrong as people who said that in support of the Pentium 4 SKUs.
The TDP arguement seems out of place here though. People who are overclocking their CPUs are scoffing at 220W, but the reality is it's basically just a figure that includes a pretty heavy overclock. Haswell has a nice 84W TDP, but everybody whos heavily overclocking is pushing 150W+ at least. It's bizarre people are forgetting that.
Pointing out the TDP is fair in context. Price wise it's up against the 3960x and that chip has a TDP of 130W. If you are going to self OC then this chip isn't that relevant just as the 3960x isn't that relevant. That's where the 3930K 4770K and FX 83xx would come in.
Because Intel has it's chips made at Global Foundries. Please don't pull any more of this out of you know where. TY.
Where it is said that intels cpus are manufactured at GF.??...
You dont read and then start to create straws.
Read again myb statement :
For thoses who dont waste time on semantics this means
Translation : GF process can endure higher voltage than intel process.
In that context it's fair. But the reaction seems more to be disgust at the CPU drawing 220W, when in reality any overclocked CPU has fairly horrific power consumption. TDP in performance desktops is not as important as CPUs in mobile form factors.
My point is, if TDP on the desktop REALLY mattered to people, they wouldn't overclock. The act of overclocking is contradictory to the pursuit of efficiency.
I just ran Fritz again at 4.8GHz, idle is 40w, load was 140w at the wall, so the cpu couldn't have been drawing more than 100w for 15579 nodes per second.
The joke with 220w TDP is that its not going to be 220w power draw, much closer to 300w actually if all the review samples need 1.55v :|
everything matters at some point. 220 watts for out of the box TDP is beyond laughable and is of no interest to most people here even if it was a $400 cpu. you can get the same performance with less than half the power usage. my 2500k oced to 4.4 uses less than 100 watts which is a pretty good balance.
300W would be for the whole system. AM3 is just a terrible platform, it's just way to old. the 990FX northbridge requires 20W all by itself, the Southbridge adds another 8-10W. Add in a GPU, fans etc and 300W sounds spot on, but it's not the CPUs draw exclusively.
TBH, I get that TDP does matter for some. It matters to me, as moving between university and home alot means I have to rely on gaming notebooks, and thus my interest is more in lower power silicon. But I find it hard to imagine people interested in $1000 silicon share the same view as myself, you and others here. People who build water based rigs probably don't care unless power is expensive where they live.
Suddenly Fritz become relevant for max TDP , of course
for AMD only linpack is relevant...
The 8350 at iddle is 61W and 189W under Fritz..
http://www.hardware.fr/articles/880-4/consommation-efficacite-energetique.html
Yet you re doing assumptions about 300W out of thin air.
Likewise I find it hard to imagine anyone with $1000 to blow on a CPU would even look at this chip.
We're already seeing the 8350 draw around 334w at 4.8GHz 1.5v, of course that's total system though. But it's hard for me to budget too much of that for the rest of the system considering the idle is very similar to Haswell.
If you look Haswell is around 80w idle for them, while the 8350 is around 90, this is stock, and once loaded up for them Haswell "jumps" to 132w giving it about a 50w delta, whereas the 8350 jumps from 90w to 283, or basically 193w accounted for the cpu.
Likewise if we look at Haswell overclocked, 80 -> 162 shows a 82w delta, on the other hand 8350 90 -> 334 (4.8GHz 1.5v) has a 244w delta. So it's not hard for me to stretch this new $1000 chip of AMD out to 260-270w at stock.
It's definitely for people who love AMD and have excess funds
This chip drawing 220W as opposed to the 244W of that 8350 can be explained by silicon quality. I don't know what Piledriver is like, but I remember with the 8150, there were absolutely massive differences in leakage between individual samples.
To the extent that a leaky 1.2v 8150 would run measurably warmer than a 1.35v non-leaky 8150. Yes, the stock VIDs actually ranged from 1.2v->1.35v or so. The 8150s were horrible. If such wild discrepancies still exist, 220W for non leaky silicon is not a stretch, imo.
I like the discretanpcy in power comsumption from various site ,
no doubt that you didnt pick your graph randomly....
45% more than TR...or HFR.
http://techreport.com/review/23750/amd-fx-8350-processor-reviewed/4
The point is not power consumption alone. It is the performance you get for that power. Even in the fx favorable benchmarks given, it was only somewhat faster than a stock Intel quad or hex core. If the price is reasonable, say 300.00 to even 400.00, I could see accepting the power usage for certain cases, but if it is in the 800.00 range as rumored, i see very little to justify getting it.
Can it? Without AMD releasing the specs the 220W is totally meaningless.
Status
