[FINISHED] Wiretap's v351 Project
nitromullet
9,031
36
You have a very good eye for the catchy, but not gaudy. Well done on a beautiful, eye catching, and tasteful build.
wiretap
642
It works quite well. I'm running at 4GHz right now (20x200) and processor temps are in the high 40's. It's a little more than I expected, but I realize I'm running low speed fans inside a very small case with a slim radiator. I've done some gaming and stuff, and it stays around the same temp pretty consistently. =)
wiretap
642
Thanks guys.
Here's a few more I took today with the point and shoot.. two of them under a black light.
zagood
4,102
Turned out great. Very clean.
Two things I'd do...paint or anodize the IO plate (black maybe?) and replace the silver thumbscrews on the back with low profile bolts. But that's just me, great job.
wiretap
642
I updated the BIOS the other day to version 44.. it seemed to stabilize my overclock and lower the temperatures. Idle CPU temp is reading 38-42C and core temps are reading ~50C. Under extreme load and benchmarking, CPU temp goes up to 55-58C and core temps in the mid 70C range. It quickly cools back down though.
Here's a few benchmarks.. (ATI drivers are shitty..)
Stock everything:
CPU @ 4.0GHz
GPU @ 900MHz core / 1250MHz memory
(quite a ways off from my old quad-sli 295 setup which scored 35689, lol)
Super-pi:
Cinebench R11.5:
ExcaliburMM
613
www.Staredit.net
You do realize you've given me no choice but to do an mATX build myself right? :p
Oh well, there goes the next paycheck. Now I just have to pick out a nice cube case.
wiretap
642
I'm not sure the tallest HSF that would fit. Just with a rough measurement, about 13cm tall from the processor until you bump into the power supply.
edit: Max height from people on various forums.. they're saying 125mm.. so 12.5cm.
LOUISSSSS
8,771
57
i'm gunna post heatsink recs in my V351 thread, please come visit =]
Rhentno
1,617
What PSU did you use? I'm finding it difficult to wedge the ones I have in and need to get something else. Very nice looking build. You ever see this site:
http://www.million-dollar-pc.com/
The V351 they have there has some competition!
wiretap
642
Yeah, I'm hoping million dollar pc will put me up there. =)
The PSU I used is the Zalman ZM500-HP. It fits with plenty of room to plug in the connectors -- roughly 1.5 inches.
If you wanted to fit a large, 1000w+ PSU in the case, the best way would be to cut out part of the 5.25'' bay that is directly across from the PSU.
