- Sep 28, 2006
- 642
- 0
- 71
I went to Home Depot today and picked up a piece of 1'' square angled aluminum. I cut it to down to the proper length and shortened one of the sides to make the radiator bracket. It still needs to be drilled for the radiator holes, then riveted into the case where the fans are up front. The short side will bolt to the radiator (for easy removal of the rad), then the longer side gets riveted to the case.
