wiretap
FINISHED PICTURES START AT POST #66
Final Specs:
- Intel i7 920 @ 4GHz
- 6GB DDR3-1866 Corsair Dominator GT
- EVGA x58 SLI Micro Motherboard
- XFX ATI Radeon HD 5870 @ 900MHz core / 1250MHz memory
- 300GB Velociraptor HDD
- VL System LIS2 Premium VFD & Fan Controller
- Zalman ZM500-HP Power Supply
- EK Supreme 1366 Waterblock
- Magicool 2x120 Slim Radiator w/ Noctua NF-S12-1200 fans
- XSPC 750 Dual Bay Reservoir w/ Pump
- PrimoFlex Pro 3/8'' ID Red Tubing
- Koolance 10mm Anti-kink Metal Springs
I'm building a new gaming PC. I am going to be using a Lian-Li v351 micro-ATX case which is going to be watercooled. I'm cooling the CPU only since there's not much room inside for a big enough radiator to dissipate tons of heat. I will be using an i7 setup with a ATI 5870.
I am going for a black and red theme, something I haven't really done yet in a PC for myself. Red is my favorite color as well. The case is black of course, and I'm going to be anodizing some of the parts red that are normally silver.
I'm going to be working on this over the next month or two (as well as some other projects and school/work), so it may be a little slow, but feel free to comment or give suggestions.
The pieces are coming in week by week, so here's what I worked on in some of my spare time today.
XSPC x2o 750 Reservoir
I installed the 3/8'' barbs and did some cable sleeving on the power cable.
The LED that came with the unit was blue and had a super long cord. I took a trip over to RadioShack and purchased a ~800mcd wide angle red LED and a 100ohm resistor to make the new dongle which goes in the back of the reservoir to light up the water.
More in a bit.
Final Specs:
More in a bit.
