Everyday OC on a 920 DO?
Elfear
7,165
824
I'm running my D0 at the specs in my sig. Temps under OCCT are right around 60C with my budget cooler. If you're wanting to stay at stock volts, I don't think 3.8GHz is unreasonable given you get a decent D0.
If you want to save a little money on the board, I'd suggest a Gigabyte UD3R. Had one for about 6 months (ended up replacing it because of a bad bios flash) and it was a great overclocker and very stable.
Shmee
8,250
3,140
mine runs at 4.2 GHz, but needs a bit of extra vcore. This is pretty much its max. Right now it is set at 1.4 V in bios. motherboard in sig. Linx gets around mid 70's. Also using a TRUE black, but I am not sure of the revision.
I also have a Q6600 at 3.5 on an nvidia board :D (evga 780i ftw) also at about 1.4 V.
GLeeM
7,199
128
I was thinking of aiming for an OC of 3333. Any thoughts?
That should be easily do-able.
Remember when reading about others' OCs that many of the best ones are with HT off, but they don't say it.
Word of warning: I have the P6T Deluxe V2 - you have to lock the vcore to what you want by setting it in BIOS or it will "auto" increase as you increase BCLK!
Ben90
2,866
Well I'll definitely keep a new cooler in mind. However I'm trying to keep the cost down for this upgrade, so I may suggest the TRUE or Megahelms as a fathers day gift. :)
Honestly I wouldn't worry about it, I'm running 4ghz (HT off) on the stock cooler right now. Sure I can hit TJmax if I run something like Intel Burn, but the heaviest load it sees under real world usage is 4x F@H. Temps are ~20 DTJmax with a 22C* ambient.
2March
135
stock voltages.
I'm still undervolting at 1.256V
At stock voltage I get almost 1.5V at 3.8GHz.
It begs the question: What's so stock about stock voltage? :)
To the OP 3.6GHz should really be fine for a D0 (and a C0 for that matter)
Rubycon
Madame President
Aug 10, 2005
17,768
485
That's not stock voltage that's AUTO voltage. If one overclocks they MUST NOT use auto voltage! As you increase BCLK the AUTO setting will AUTOmatically raise VCORE and the setting is quite aggressive often much more than needed.
2March
135
I hear you,
The problem is that I'm using a P6T and the only Vcore settings are auto or manual. The Intel DB claims stock Vcore for the 920 is between 1.0V and 1.35V (IIRC) so what is stock voltage? :)
I don't know how this works on other X58 MB's but I'd be interrested in the exact number...
Gillbot
28,830
17
I hear you,
then look at your VID and set it manually. I never NEVER use AUTO for any voltage.
Rubycon
Madame President
Aug 10, 2005
17,768
485
1.2000 is a real nice round number that's taken me to 4.2GHz on better chips. ;)
Markfw
May 16, 2002
27,286
16,123
The vid used to show up on coretemp, but not anymore. Where can I find this ? bios@stock defaulted to 1.2875 or something high.
Gillbot
28,830
17
I think realtemp shows it somewhere but I don't recall where. This machine uses coretemp so I can't look. I'll see what I can dig up.
2March
135
Obviously neither do I. But I would have liked to use it since I also still use EIST and turbo while OC'ed to 3.6 -> 3.8 /w turbo. I like the idea that it runs only a 12 divider and 2160 MHz when there is no load on the system. Only then the Vcore is way too high because it is fixed. No biggy though. I just did it the old fashioned way. Tested the system at different Vcores untill I found the lowest possible stable Vcore.
Rubycon said:
1.2000 is a real nice round number that's taken me to 4.2GHz on better chips. :)
Darn, you lucky D0 owners :) Need 1.256 for 3.8GHz on my C0.
But still. Everyone is talking about how high these chips go at stock Vcore. Meanwhile everyone is using a different value for stock Vcore :D
To Markfw900: these are some autovalues from my i7 920 on ASUS P6T-DL:
2.66GHz - Vcore=1.048V (1.28V full load)
3.33GHz - Vcore=1.232V (1.248 full load)
3.6GHz - Vcore=1.408V (1.432 full load) with loadline callibration disabled it was 1.408V/1.35V...
Gillbot
28,830
17
not all D0's are created equal, IIRC my brothers takes 1.35 or so to hit 3.7ghz.
Markfw
May 16, 2002
27,286
16,123
it should show it on the settings page:
http://dailyfreeware.net/wp-content/uploads/screen1.jpg
the max is for full speed, the min is for when speedstep is on
I downloaded the most recent version. Here is what I see (no VID)
Rubycon
Madame President
Aug 10, 2005
17,768
485
I know - I would be lying if I said everyone I had was a gem. Some were getting stubborn at 3.6. Like I've said before it's a lottery. Not every ticket will be a winner. Most go in the trash can!
Makaveli
4,984
1,576
You know what this is a very good question what is the stock vcore is it 1.2 or 1.25?
Rubycon
Madame President
Aug 10, 2005
17,768
485
Depends on your VID.
What's important is providing enough voltage to keep the CPU error free at the speed you want to run. At highest speeds temperature will be the limiting factor unless you're using high capacity cooling. (liquid, chillers, etc.)
spdfreak
971
"I'd like to keep it at stock voltage and keep speed step / turbo boost enabled."
No one really answered this question for him. I'd also be interested in people's experience with this scenario. I honestly don't do anything on a consistent basis that needs 4GHz. Maybe 5% of what I do is photoshop or an occasional video trans-code.
Gillbot
28,830
17
On my W3580, I set the voltage manually in the bios to 1.25v, upped the multi for 3.6GHz and left speedstep on. It still throttles the voltage down with speedstep on my board.
Gillbot
28,830
17
From the RealTemp website:
Core VID
This is the Minimum and Maximum voltage that your processor will request from your motherboard when the Voltage is set to AUTO or Default in the bios. Depending on your motherboard and how it is set up this voltage request may be ignored. Core VID is a suggested voltage and may not be the same as the actual core voltage that your processor receives. Use a program like CPU-Z to report actual core voltage. Core VID is no longer supported with the new Core i7 processors.
Gillbot
28,830
17
Looks like the most common way is to set everything to "stock" or "auto" and see what CPUz reports for voltage.
The only other info i've found is the intel page which isn't any help:
http://processorfinder.intel.com/details.aspx?sSpec=SLBEJ
VID Voltage Range: 0.80V-1.375V
Looks like stock on my W3580 should be 1.225v so i'm actually above that a shade with 1.25v. UH OH! ;)
