On my W3580, I set the voltage manually in the bios to 1.25v, upped the multi for 3.6GHz and left speedstep on. It still throttles the voltage down with speedstep on my board.
So it looks like 3.5-3.7GHz would be realistic with stock voltages and speedstep/turbo on. That will be plenty fast for what I do. I'm currently using a Q6600 at 2.8 which is as fast as it will go at stock voltage. I'm guessing that a good aftermarket cooler will still be needed at those speeds?
This.No, my chip is not a 920 D0 for one, and two, you should never assume anything besides stock is a given.
While obviously this is true, I think that what most people (including me) are saying, is that 99% of 920 D0 chips will do 3.6 on decent hardware. I won't even go so far to say as on stock vcore, but I think the percentage drops to 80 or 90% in that case.No, my chip is not a 920 D0 for one, and two, you should never assume anything besides stock is a given.
Also of note: It appears that my stock vcore is pretty high (1.28 something)
My every day overclock is 3.78GHz (21 x 180) with 1.25V. Temps stay at low 70C at full load according to RealTemp. Specs in sig.
I've been running this 920 D0 for half a year at this speed and stability has been solid the whole time. It's gotten kinda boring actually.
Stock Cooler / Cheapest ASUS board in the world got me to 3.78 @ 1.2v HT OnHow did you test stability?
HT on or off?
What hardware are you using?
These are the problems with these types of threads and posts. Anyone that doesn't know any better is going to assume that ANY motherboard and ANY cooler will get them to 3.78GHz with 1.25v, but you left out a lot of pertinent info.
HT on or off?
I found that a second fan did not bring temps down enough to warrant its use on a TRUE. The Megahalems did benefit from it and that's my current config. 4.45GHz 1.33V HT ON mid 70's Linpack after eight hours. 🙂
this is the most awkward necro i've seen.
I've been running an i7 920 @3.9GHz for 2+ years, still a champ in any game I throw at it. I see a bunch of friends jumping on the "next big thing" wagon, but I haven't felt the need to upgrade at all.
