Yay, my suggestion wins out! UM students always have the best answers.![]()
best stupid answers?
Originally posted by: slycat
uhm...no one asked this?..
PICS?!
just pick it...it won't scar if its on the forehead...only if its in the lower T zone.
however, if its not ripe yet, don't bother...u'll just anger it into spawning its brethens.
Only real true way to get rid of it FASTEST...when i say that i mean 2 days...u need antibiotics.
If u can get some erythromycin 250mg...take 1 tab every 4 hrs...in the next 48hrs that pimple
will be gone and u'll be somewhat detoxified...and glowing for the weekend trip. Its the only real
proven way....the rest are hit or miss....mostly miss, if ur trying to get rid of it within 48-72hrs.
Originally posted by: jumpr
Yay, my suggestion wins out! UM students always have the best answers.Originally posted by: Dezign
Okay... I really don't want to spend $30+, so I've decided to try the rubbing alcohol (to disinfect), warm press with a clean towel, and possibly the mint julep mask after that.
You're all the best...Hopefully it's gone by Friday evening...
I wouldn't go with slycat suggestion, because antibiotic is not the answers to all cure. Antibiotic should be taken seriously, because it weaken your immunity and strengthen the bugs to develop more resistant to it...making antibiotic not as affective in the future, when you really needed it.Originally posted by: Dezign
Is erythromycin prescription medication or available over-the-counter?
Ask the pharmacists for assistant, because they will be the best people to give you the answers.Originally posted by: Dezign
Very true... although this would definitely be a one-time-usage deal. Okay, gonna try the natural way... off to the store during my lunch break to buy some rubbing alcohol.![]()
Originally posted by: aircooled
sqeeze... click... ker-splat.. wipe mirror with tissue...
Originally posted by: TranSoft
Here's my Home Remedy Pimple TREATMENT/PREVENTION...
in the morning... use your saliva...apply to face, then clean off... (pee works too but many may not be comfortable with that)
steam face before doing any popping, cleaning n stuff... by turning up hot water in the sink and cover my head with a towel so that the steam stays in and loosen my pours for easier cleaning popping and blackhead removals.
always wash your face ... at least every 3-4 hours... that helps!!!
any convential face cleanser would work with this process.
Originally posted by: brigden
DON'T wash your face every 3-4 hours. It will only dry out your skin and you'll likely break out even more. Your face is oily for a reason, to protect the skin.
You are right that oil is what keeps our skin moist, and protect a protection layer from the environment. But, oil is what encourages bacterial growth. It is a dilemma, but locally drying out an infected area is a good method to hamper bacteria growth.Originally posted by: brigden
Wash your face & use facial scrub.Originally posted by: ElFenix
ok, how do you get rid of blackheads?
:Q
So, you're saying you apply pee to your face . . .?
