Eh what the hell...UPDATED WITH CARD IN COMPUTER
Page 19 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Elfear
7,163
819
If I flash to the LE-GT bios, is 1.5V too much to run 24/7 and have it last a few years?
Cannabis
155
I would go with the 1.4V as the 1.5 didnt help my OC any but did cause a significant increase in temps.
THUGSROOK
11,847
Originally posted by: Cannabis
I get the same max OC of 460/1170 whether I use the ultra bios or thugs le-gt. Howver I get better performance at the same speed with the le-gt.
nice OC :Q
my 6800LE needs the LE-GT 1.5v just to pass 420mhz.
still a great card tho :)
ronach
Kabob983, re; my post of 10-20-04, ref useing other pwr supplies, go for it, just blow out the older one and make sure you strap or ground the pwr supply shell to your metal computer case/frame with 1/4" copper braid or screws. I don't know the current draw of this unit. Good luck.
AWhackWhiteBoy
1,807
I went from a score of 5,200 in 3dmark 05 with the ultra bios to almost 5,600 with the le-gt bios.
thanks, this was extremely helpful, and thanks thug, now i can't wait to get this god damn card :)
Fenring
8
I would say check out the bios and make sure everything liike good. In the book that came with the card it sayd what they recomend the bios settings to be. Let us know though.
Hmm Im really more of an enthusiast-light, so ya know clue on how to do that or what I'd look for. The only thing I can think of is, at home I used Rivatuner to OC to 350 core, then I used riva to restore default driver values. From there I just popped it out and brought it to my main PC.
Gandolf1
22
Originally posted by: Joe Camel
this is a thread i started on OC.com about this card.
( http://www.ocforums.com/showthread.php?t=338050 )
im getting 450/1180 out of my card :shocked:
i had the same problem with the "mismatch" while flashing (post #25)...post #26 has the way I got it to flash. (this was/is the first time i ever flashed a video card)
GOOD LUCK and.... AWSOME work THUGSROOK!!!!
How do you determine the post #
crocogator
:)got card up and running last night.. flashed to ultra,clock 425/1100 RAN ALL NIGHT .LOOKS GOOD SO FOR...3dmark03--12487
3dmark05--5133
p-4- 3.2e 1 gig ram-2225 timing--p4c800e...
Elfear
7,163
819
Is it possible to use the LE-GT bios and lower the voltage to 1.4V so that I can still take advantage of the tighter timings?
Killrose
6,230
8
I'm interested in seeing if any of the people who bought these cards from other vendors like Zipzoomfly, ect., have any luck with these cards. The Zipzoomfly link to the eVGA site shows 12pipes listed inthe specs for the 6800LE cards.
Hopefully my Newegg card gets here tommorrow :)
Vallybally
259
There are 2 versions of most of these BIOSes Elfear. I'm prolly gonna try Thug's LE-GT 1.4v myself.
Can someone explain to me the difference (or effect one has on the other) between vCore (AGP voltage via mobo BIOS) and these video card BIOS voltages of 1.3/1.4/1.5 etc???
Reason I ask is because my mobo is defaulted to 1.55 agp voltage, yet does that impact in anyway if I flash my video card bios...
Nebakanezzar
388
hey all,
went through the steps to flash my bios, I think it worked, but....um...how do i check ? all i see is 6800, no LE , GT or ultra...
thnx, sorry for the stupid question..
Elfear
7,163
819
VallyBally- Are you going to flash your card and then look for max OC, or are you going to set it @Ultra speeds and leave it alone? I'll probably just do the latter so I can set it and forget about it.
imported_k00k
27
So Thugs, what's the latest BIOS that you're using and where can we download it?
I assume the latest is the following one in aonic's bootdisk, yes?
LE-GT.rom [ LE - GT with 1.4v (THUGS) ] 1.1 / 1.4 / 1.4
TIA for the reply.
aonic
139
Nebakanezzar
388
Ok, so I couldnt seem to get thugs bios to flash, so i just did the regular ultra bios...it did work! And the problems i was having with artifacts is all gone bye bye! and i am running at 425! yeah! i am stoked!!!
it looks like it is running at 59 idle and 75 under load using the temps that are in the Nvidia utility. are these high? what do you guys use to monotor temps? since i am OC'ing this, i figure i better keep an eye on it to make sure i dont fry it!
Also, what do you guys use to stress test to make sure it is rock stable?
thanx in advance...and thanx to all you out there showing us all how to do this!
aonic
139
what temps were you gettin in LE bios.. and what are the Ambients reported by your motherboard and the card
Nebakanezzar
388
amioent is 40...i think ti was 37 with LE bios and 54 idle....never checked it under load...
not sure how to check ambient on the MOBO, but i get two temps with MBM5 48 is the cpu, the other is 33...not sure if that is the ambient or not...
aonic
139
ya thats about the same temps i get..
i get max load of 70C in LE but with GT or Ultra i get the max of 80C but mostly around 75C
and btw the 33 is the ambient/case/system
Killrose
6,230
8
Originally posted by: aonic
the latest one he has posted is the LE-GT14 and the LE-U14
:p
can you guys also post your temprature changes from LE to custom flashed bios
thx
and for the ultra id:
flash your bios, get the drivers.. then:
http://aonic.net/~aonic/riva.jpg
^ this shows ULTRA even tho im using the LE bios
and goto NVSTRAP tab and change the settings like so
http://aonic.net/~aonic/riva2.jpg
then apply, reboot and your done!
result: http://aonic.net/~aonic/riva3.jpg
So this ID utilty works only as long as you are running Riva tuner and does not work with any other app? or does it actually modify the bios?
aonic
139
it doesnt modify it. it works with every program.. everything see's your card as an ultra (as showed in result pictured)
the ID utility works with low level
straight from rivatuner FAQ:
Q: And what about the low level overclocking? Will it work if RivaTuner is not loaded at Windows startup?
A: Yes, it will. The only condition is not to remove RivaTuner's folder from your hard drive. RivaTuner adds itself with the /S command line switch to the autorun registry key when you enable any low level settings (e.g. overclocking or color correction) at Windows startup. When this command line switch is specified, RivaTuner loads itself at Windows startup, executes startup daemon (the procedure that configures startup settings depending on the settings you've made) and unloads itself from memory immediately.
heres a updated version of my boot disk
features:
Backup:
nvflash -b backup.rom /REMOVED/
WFFLASH.EXE -S backup.rom
Install:
nvflash -5 -6 file.rom /REMOVED/
WFFLASH.EXE NM file.rom
List:
LE-D.rom
  • Default LE bios with 1.3v ( 1.1 / 1.3 / 1.4 )
LE-GT.rom
  • LE - GT with 1.4v (THUGS) ( 1.1 / 1.4 / 1.4 ) UPDATED to 350/1150 version
LE-GT2.rom
  • LE - GT Real Bios with 1.3v ( 1.1 / 1.3 / 1.4 )
LE-GT2mod.rom
  • LE - GT Real w/ 350/1150 MhZ / 1.3v ( 1.1 / 1.3 / 1.4 )
LE-U.rom
  • LE - Ultra Real Bios ( 1.1 / 1.3 / 1.4 )
LE-U2mod.rom
  • LE - U Real w/ 350/1150 MhZ ( 1.1 / 1.3 / 1.4 )
Note: For LE-GT2mod.rom you must do WFFLASH.EXE NM LE-GT2~1.rom
Note: Thugs LE-GT is updated to 350/1150 with Rev2.. and all the other bios' are latest revision
link: http://files.aonic.net/eVGA-BIOS-FLASH-DISK2.zip
THUGSROOK
11,847
all bios files offered in my thread have been updated.
* idle temp/clock fixed!
* dual mode clocking fixed!
* dual mode fan speeds fixed!
* LE-GT bios now based on 6800GT rev02
aonic
139
* dual mode fan speed fixed
what do you mean?
the fans actauly work now with dynamic settings?
