Draw Call Performance In Fallout 4
MajinCry
2,495
572
Look what I've found, maybe this thing will help identifying hardware performance issues.
https://docs.unity3d.com/uploads/Ex...rformance_using_Event_Tracing_for_Windows.pdf
We know what the main performance problem is, actually; it's the time spent processing draw calls. If you launch Process Hacker and point it to Fallout4.exe, it's the driver thread that eats up CPU time when in draw call intensive scenarios (i.e, Corvega, Diamond City).
Still waiting for someone with Ryzen to give it a run on one CCX, so we can see the real-world performance hit by CCX intercommunication. Would be interesting if we see the Corvega results reach 60fps.
CombatLemon
4
I think it's the best benchmark I'v ever seen for FO4 :)
OS: Win7 x64
CPU: i7-3930K @ 4.5 GHz (HT off)
RAM: 4x4 GB DDR3 @ 2400 MHz (9-11-11-31-1T)
GPU: GTX 980 Ti @ 1455/7900 MHz
GPU Driver: 385.41
First Save (Corvega)
Draw Calls: 11704
FPS: 60.9
Second Save (Diamond City)
Draw Calls: 8025
FPS: 72.3
My system is pretty old (except video) :expressionless::
Reactions: psolord
CombatLemon
4
8700K @ 4.8 GHz / 3000-14-15-15-30-T1
Corvega 81.6 FPS
Diamond 95.8 FPS
8700K @ 4.8 GHz / 3500-17-17-17-35-T2
Corvega 80.4 FPS
Diamond 95.7 FPS
8700K @ 4.8 GHz / DDR4 3000-17-17-17-35-T2
Corvega 75.9 FPS
Diamond 90.3 FPS
8700K @ 4 GHz / 3500-17-17-17-35-T2
Corvega 70.9 FPS
Diamond 83.5 FPS
MajinCry
2,495
572
Corvega 81.6 FPS
Diamond 95.8 FPS
Corvega 80.4 FPS
Diamond 95.7 FPS
Corvega 75.9 FPS
Diamond 90.3 FPS
Corvega 70.9 FPS
Diamond 83.5 FPS
What's your GPU and OS? Those are some very nice FPS scores for Fallout 4.
daveybrat
5,830
1,042
Come on folks, this is labeled as a Ryzen w/AMD Gpu thread. Some of you are getting off topic with nothing but Intel/Nvidia benchmarks.
Keep to the subject please.
TheELF
4,029
753
We also need results from users with Intel CPUs, to get a clear picture of where it stands. According to that draw call benchmark thread, Ryzen is better than Core 2 Duo, but worse than Sandybridge at draw calls. Intel's later architectures only get better with them, too.
Well then the topic starter got off topic on his topic....
Don't just try to shut down any kind of conversation just out of fear.
If you have an issue with moderation,
you create a post in moderator discussions.
You DO NOT do this.
AT Mod Usandthem
gamervivek
490
53
OS: Win10 Home
CPU: Ryzen 1600 @ 3.5Ghz
RAM: 4x16GB DDR4 2666MHz 14-14-14-35
GPU: Gtx 1080Ti aorus waterforce
GPU Driver:391.35
Draw Calls:11700
FPS:47
Draw Calls: 8100
FPS: 55
Will put in Vega one of these days to check how well it does.
PhonakV30
987
378
OS: Win10 Home
GPU Driver:391.35
Draw Calls:11700
FPS:47
Draw Calls: 8100
FPS: 55
wow!! it's pretty damn bad compare to 8700K at 4Ghz
Edit : I noticed you used DDR4 2666.How about at 3200 Cl 14 ?
USER8000
1,542
780
Ryzen 2 has some good improvements in the game.
14687
Some benchmarks from a system with a Ryzen 2 CPU would be useful.
Reactions: lightmanek
Markfw
May 16, 2002
27,394
16,236
14687
But what memory did they use ?? 3466 CL14 might make a huge difference. I was going to try this when my motherboard cam in, but I don't have this game.
But I DO have 3600 CL15, that I am sure will run 3466 CL14 on my 2700x@4.(something) ghz
Reactions: wilds and Drazick
CombatLemon
4
OS: Win7 x64
CPU: 8700K @ 3.5 Ghz (cache 3.5 GHz)
RAM: 2x8GB DDR4 2666MHz 14-14-14-35
GPU: GTX 980 Ti
GPU Driver: 390.65
Draw Calls: 11717
FPS: 62.5
Draw Calls: 8012
FPS: 73.4
To be honest, I don't think that anything can help Ryzen in this situation. Also, I doubt that the graphics card plays any role here.
Reactions: MajinCry
.vodka
1,203
1,538
OS: Windows 10 Pro 1803 (17134.1) x64
CPU: Ryzen 7 1700, relaxed EDC on, performance bias on (CB15), Ryzen Balanced power profile
RAM: 2x8GB DDR4-3466 + Stilt's 15-15-15-35 1T profile with proper subtimings
GPU: R9 290 @ 1100/1375 + Stilt's MLU BIOS
GPU Driver: 18.3.4
Motherboard: ASUS C6H + BIOS 6101 (Pinnacle-PI 1.0.0.2)
3800MHz
Draw Calls: ~11693
FPS: ~44.6
Draw Calls: ~7995
FPS: ~57.5
3950MHz
Draw Calls: ~11680
FPS: ~46.8
Draw Calls: ~7990
FPS: ~59.9
GPU clock speed would stay at ~900MHz in Corvega and ~950MHz in DC, not 1100MHz, so these tests are CPU limited. 4% clock speed increase, 4-5% FPS increase as expected from a CPU limited test.
Limiting fallout4.exe to CCX0 or CCX1 (affinity set to CPU 0-7 and 8-15 in task manager) didn't change anything. No changes in FPS value in both cases.
Looking away to the ground/sky shot FPS up to 200-250 FPS.
Let's see how it performs in a 4+0 configuration, completely disabling CCX1 and 8MB of L3 in the BIOS:
3800MHz
Draw Calls: ~11696
FPS: ~47.1
Draw Calls: ~7990
FPS: ~58.7
3950MHz
Draw Calls: ~11688
FPS: ~48.4
Draw Calls: ~8005
FPS: ~59.7
Hard limiting everything to one CCX, at 3800MHz nets me that 150MHz increase, and at 3950MHz there's an expected performance bump. Interesting, at >3200MHz and especially 3466MHz memclk, latency between CCXes is brought down to non issue levels, but still.
It would be nice if someone with a 2700x could chime in and test. That juicy 4.35GHz single threaded turbo and all the latency improvements should make a noticeable difference here.
PhonakV30
987
378
OS: Win7 x64
GPU: GTX 980 Ti
GPU Driver: 390.65
Draw Calls: 11717
FPS: 62.5
Draw Calls: 8012
FPS: 73.4
So according to my post , Ryzen 1600x gets 47 , 55 ==> 62.5/47 = 32.9% , 73.4/55 = 33.4% , this huge different can not come from memory latency.something deeper than those
Edit : What's your latency at DDR4 2666 ?
gamervivek
490
53
OS: Win10 Home
GPU Driver:391.35
Draw Calls:11700
FPS:47
Draw Calls: 8100
FPS: 55
Vega56 results:
Draw Calls:11700
FPS:39
Draw Calls: 8100
FPS: 40
MajinCry
2,495
572
Vega56 results:
Draw Calls:11700
FPS:39
Draw Calls: 8100
FPS: 40
Damn, Vega doesn't have a good showing there. I wonder if the driver performs differently on Vega than it does on Polaris, and the older 300 series. Earlier results showed that AMD was pretty close to NVidia for draw calls, but your result shows differently.
B-Riz
1,595
765
I will try this once the 2700X / 1080 Ti setup is back to working :(
But it can only run the 32GB RAM CL14 3000 stable, not 3200.
Markfw
May 16, 2002
27,394
16,236
Well, my 2700x is running 3466 cl14 stable, but I had to back off the subtimings, as one setting (I don't know which one) was causing lockups.
Also, I would test this, except I don't have the game.
TKbu
(I am not good at English, so I apologize in advance)
OS: Windows 10 Professional 64 Bit ver.1803(17134.112)
CPU: Ryzen 7 2700X@stock clock(with 0.1v undervolting and Customized Power Plan)
RAM: 16GB (2 x 8GB) Gskill Flare-X, DDR4-3200, 14-14-14-28
GPU: GeForce GTX1080FE(Stock core clock, MemClock +200MHz)
GPU Driver: 398.11
Draw Calls: 11045
FPS: 66.1
Draw Calls: 7858
FPS: 78.7
[Other data]
A:My Settlement (WQHD+ MajinCry's ENB Presets+bunch of mods including SIM Settlements)
Draw Calls: 19198
FPS: 53.7(push @ and move cursor to outside of window and press Print Screen.)
FPS: 56.3(with my phone cam.Actual IN GAME FPS)
B:My Settlement (WQHD+My Reshade Presets+bunch of mods including SIM Settlements)
Draw Calls: Unknown(same save data&location as A:My Settlement. So arround 18500-19500 I guess)
FPS: 59(push @ and move cursor to outside of window and press Print Screen.)
FPS: 60(with my phone cam.Actual IN GAME FPS.)
Exchange ENB to Reshade=better FPS
Use @ and Print Screen = lower FPS
(I don't know why)
[Other data] was VSYNC ON setting. I forgot to turn off.
MajinCry
2,495
572
I'd say we have enough results now. Updated the OP with everybody's results, and will make a new thread featuring graphs over the next day or two. If anybody else wants to contribute, now's the time.
Edited: Decided to stay up to half past 3, and get the graphs all done. The new thread, replete with charts, can be found here: https://forums.anandtech.com/thread...u-draw-call-performance-in-fallout-4.2548618/
