Does anyone have their Audigy 1/2/4 hooked up to a Receiver? (With poll)
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Originally posted by: sheik124
Well, my Logitech Z-5500s aren't a "reciever", but the 5.1 analog outs work just peachy with my X-Fi, and the sub control (in the X-Fi CP) actually does something.
<-- Voted "Jello, I like you" :p
Aww thanks.
Well the z-5500s have an internal crossover that is used with 5.1 analog input, so I know those would work with any standard 5.1 analog soundcard.
I guess I should expand this to include the X-Fi too for anyone dealing with that.
Don't know if its worth anything or not, but when I turn on the X-Fi's crossover (from the THX panel) and start sending out that .1 signal, it kills the Z-5500's crossover and just uses the LFE signal its getting from the card, not its own.
I wouldn't think that was going to work quite like a regular HT crossover with a computer speaker set.
Does that mean you could set the crossover to 40hz or something and have the satellites try to play everything above that? I wouldn't have thought they would allow for that.
mrSHEiK124
11,488
Aww thanks.
Exactly what it does, and if I set it to something crazy like 200 Hz, all the higher stuff getting sent over LFE overtakes the low stuff and I end up getting nothing out of the sub, at least its enough to make me sure that enabling crossover from the card disables the Z-5500 crossover.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Aww thanks.
Setting the crossover to 200hz plays nothing out the sub? I'm confused.
mrSHEiK124
11,488
Aww thanks.
Barely plays anything out of it, I'm still not sure why setting it that high up actually reduces the amount of sound being sent to the sub.
PurdueRy
13,837
4
Aww thanks.
provided that the crossover is passive...that's highly unlikely
imported_goku
7,613
I have the subwoofer hooked up by having the front stereo speaker wires go through the woofer then out to the reciever (or vise versa) instead of using the dedicated "subwoofer" port on the back of the reciever.
Aquila76
3,549
www.facebook.com
Well, my setup (Audigy1 analog out to Yamaha receiver analog in) has the same sub issue. I have to crank the sub's level up to max and even then it's not as powerful as it normally is. I can't adjust the individual speaker levels with my driver, so I can't confirm it's the same issue as PurdueRy's, but it's quite probable.
PurdueRy
13,837
4
What card you you have?
The Yamaha can't adjust individual speakers volume?
Aquila76
3,549
www.facebook.com
It's a first-gen Audigy MP3 (Audigy1). It's also a VERY old receiver, an HTR-5150. I got it back in 98 or 99. It doesn't have level adjustments for the individual speakers, just a few DSP's (rock, jazz, etc.) and a 'night-time' mode that apparently simply lowers the high and low-end sounds. Oddly enough, it can adjust the time delay for front, rear, center, and sub and defeat the sub level for DD or DTS streams; it just can't adjust the volume level for the main speakers.
EDIT: When I was referring to adjusting the sub level earlier, I meant the control in the audio driver panel, not the physical sub's gain knob.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Can you lower the speaker levels in the audigy controls so that the sub is a good volume relative to them?
PurdueRy
13,837
4
mine is an audigy 2 ZS so he may not be able to....
Rubycon
Madame President
Aug 10, 2005
17,768
485
Turn your subs up where the rats start popping out of their crates. :)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
A mouse just popped out of my water-heater shaped SVS? Is this good or bad?
Rubycon
Madame President
Aug 10, 2005
17,768
485
Could be a telltale sign of impending disaster. Those vermin will wreak havoc on surrounds. (outer periphery of transducer suspension not the little speakers behind you!) :p
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
mmmm, Santoprene apparently
Mar 19, 2003
18,289
I can test this for you if you send me a receiver with 5.1 analog inputs :p
(FWIW there is a setting for sub crossover frequency, but obviously it isn't gonna do much of anything on my X-530's ;))
Goosemaster
48,775
It has always worked fine for me....jsut have three RCA adapter couples running from the pc to my recievers 5.1 analog inout.
gnerally, I keep my recievers crossover at 80hz and use the sub out for the sub without bothering to use the subs crossover.
As for software, I have all the drivers installed, have digital unchecked, have my spekaers et to 5.1, and the bass redirection tab is checked withthe frequency set at 80hz
equipemtn
pc with audigy2zs
3 pairs of RCA to minijack adapter cables
only tx-sr601 receiver
firage frx-5 fronts
athena psb400 sub
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Will you be needing speakers and a sub too?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
equipemtn
pc with audigy2zs
firage frx-5 fronts
athena psb400 sub
Thanks.
I thought it worked for some people and I have recommended it as a connection before.
I've seen some people who can't get it to work for the life of them though, so I wanted to make sure I could recommend it in the future.
It seems like several people have gotten it to work with just some small adjustments :thumbsup:
dawnbug
1,670
Originally posted by: Pepsi90919
WILL SOMEONE PLEASE TELL ME HOW THE JELLO IS
I like jello.
My favorite kind is orange jello with mandarin oranges in it. I also like Jello pudding varieties, and am a fan of Jello's No Bake Oreo Pudding Pie. It's delicious.
