AtaruMoroboshi18
So I should avoid the OEM versions of Processors? Because of the warranty?
Originally posted by: AtaruMoroboshi18
Alright, so I switched to a Corsair Value RAM kit back on my previous post. I need to find a motherboard though, any suggestions? I was also wondering what consensus there is for a motherboard? What is one that is PCIe without having SLI. I'm just looking for a nice gaming or all around motherboard.
Also, should I have a Combo DVD/CD drive and then a straight up DVD drive? Is that a smart thing to do or a waste of money? Remember, I probably won't be doing any overclocking. I also was wondering about the OEM versions of things, what disadvantages do they have for hard drives, video cards, memory, etc.
Originally posted by: bcoupland
Before you blow $600 on your video card, take a look at this one. The Sapphire X850XT at ZZF is 460ish, much less than the one you quoted. Also, I have not heard of "pcpowerzone".
The clock and memory speeds of the X850XT versus the X850XTPE is 20 Mhz on the core and 50(100DDR) on the memory. The former is within one or two percentage points of the latter.
Hm, got anyone sources or links on the Venice, such as when it comes out? I may have to wait for them...
BTW: I also noticed that I can't find a Winchester core on any of the stores...is it out yet, or do I need to wait for it?
Originally posted by: ribbon13
Buying a 3500 isn't the best idea anyway. The Mhz jump for the $ jump is terrible.
If you want to overclock, and are getting a DFI Ultra, I already told you the best RAM is TwinMOS
Thread about TwinMOS
What didn't you like about the SLK3000B in the first list i made you? Its very nice. photos. One of the quietest cases made. Nice heavy steel, 120mm fan, good ventilation scheme, and grommets on the HDD cage.
I see you went with the zipzoomfly card I mentioned earlier. Your $10 off on the price though 😛
