CrystalMark 2004 Competition! Stress your System!
Duvie
16,215
Originally posted by: coomar
duvie what are you talking about, sp2004 is just prime95 with a different graphical interface, i like it because I can tell how long its been running since it has a clock feature as well as it records cpu temp every couple minutes so i can scroll and see what temperature it was running at overnight instead of mm5's high/low/average/current
Sorry I misqouted the wrong post...I meant to quote this one....
Duvie,
No Im not joking. That was just showing both instances running on both cpu's at once, Its been 6 hours of prime 95 and its still running, and like I said I can have quake 3, internet explorer, AIM, Prime95, and crystal mark going at the same time. How much more stable do you want?
It was right below your thread....
He is running 2 instnaces of the benchmark and not the torture test ad he thinks this means stability....
I can run those at 2.66ghz with 1.47v but wont pass prime for 1 minute....
alrox
175
100% stock settings
Pentium D 820, 2 2.8ghz CPU's
1gb Dual channel DDR2-667MHZ 5-5-5-5 15
MARK: 34536
ALU:12456
FPU:13334
MEM:8746
rise
9,116
46
3700 @250x11, 2.5-3-2-8, 2x1024 2.65v
31,242
still messing around with these mushkis. they run @2.5-3-2-6 but i don't see any difference, like :08 in pi 32m.
Duvie
16,215
yeah i was confused at what he was running, i assumed it was a new version of prime
I have the latest version and the ebenchamrk tool is still the same as it always has been....It will not even find errors...I can imagine one can do this even on extremely flaky system. Now he has done other test so it is likely it is somewhat stable....
Godsmack74
808
Ok guys, I have run Prime 95 at the same time as alcohol for the last 16 hours and its still up and stable. Now are ya happy?
IEC
14,604
6,091
26072 marks with a conservatively-clocked Sempron 3300+ @2.4GHz.
26072 for now, will push it later
I bet if I were to push the chip to 2.6GHz (I've done it before) and run the RAM at 433MHz after divider (again, done before) on a clean install on nLite'd Windows I would break 30000. We'll see in a few days. ;)
For now I think I get 20th in AMD... lol
MADMAX23
527
I have been abroad for the last 3 days, I'll update the scores as soon as possible guys, sorry!
Be happy!
monster64
Banned
Jan 18, 2005
466
31,242
No way you got over 31k with a clock speed of less than 2ghz, especially at 1.5 ghz. Looks like that cpu-z screen is copied and pasted.
rise
9,116
46
lmao, yeah crystalmark is that important to me :p
anyway, thats just cool n quiet, it runs 11x250 like i said. c n' q runs at 6x
MADMAX23
527
Originally posted by: alrox
100% stock settings
MARK: 34536
ALU:12456
FPU:13334
MEM:8746
Post a pic showing CPU-Z!
MADMAX23
527
100% stock settings
MARK: 34536
ALU:12456
FPU:13334
MEM:8746
MADMAX23
527
Scores updated!!
Zebo: congratulationss for buying a X2 4200+ and an Abit. I am thinking about buying the ABIT AN8 Fatal1ty SLI...
GuitarDaddy
11,465
31,242
Looks like he's using Cool n' Quite, and his CPU-Z is after it throttled back down.
Velk
734
The results from the crystalmark bench seem a little flaky - particularly the first FPU test - when I run it, it usually gives ~2700, but every so often it will give 500, 700 or 1000, for no obvious reason. I'd say caching, except that it gets the 2700 speed first run immediately after a reboot.
*puzzled*
MADMAX23
527
ronin score corrected: now it's in the AMD Dual Core section...THANK YOU GUYS AGAIN!!
Have a nice day!!
ND40oz
1,264
Alright, I just pulled out an old HP DL380 G3 (Prestonia), it's got 3.06 Dual Xeons w/ HT, 4 gigs of pc2100 or 2700, I'm sure its the 533 fsb thats killing its score. Not bad for a 2 year old box though.
ALU - 15669
FPU - 15873
MEM - 6432
Total - 37974
On a side note, I got an HDD score of 6999 with 3 Ultra320 SCSI @ 10k in raid 5.
Now i'm off to find a G4 with dual 3.4 gig Xeons...
ty1er
807
Total - 38529
PIC
System Specs:
Dual 3.2 Xeons (running stock)
1GB (2x Micron Technology DDR2-SDRAM PC3200 - 512 MBytes)
ND40oz
1,264
ALU - 15669
FPU - 15873
MEM - 6432
Total - 37974
It fluctuated a bit when I reran it, but here's a screen grab. I'm at 38268.
ND40oz
1,264
ALU - 15669
FPU - 15873
MEM - 6432
Total - 37974
Just ran it on a Dual 3.2 Xeon with the Nocona core. This should be at the top of the heap for intel systems. 48002. I guess don't bother with my previous score unless you want it for comparison.
Buck Naked
706
I finally have some spare time to play.
It was getting a little hot. I've seen 60, and thats with my XP120.:(
I should have water cooling in place by Aug. 13-14.:)
I can't wait.
