CrystalMark 2004 Competition! Stress your System!
MADMAX23
527
Originally posted by: chinkgai
hi guys, back in the game after about a week of tweaking
seems like at the current moment, i've found the chip's max stable is 2751mhz
anyways, sorry godsmack...thanks for keeping my seat warm, but i've come to regain the throne ;)
my new score of 59533
and is it prime stable? why yes it is
dual prime torture test, not benchmark shot hehe :D
oh madmax, i've gotten a mod to fix it so my screen name is no longer a censored word, so you can put my name instead of XXXXXX hahaha
thanks for your efforts on updating this popular thread! :beer:
edit: dont forget to press refresh if the link doesnt work!
First: Very nice work with your chip,so far the best I've seen, my congrats!!
Did you run the Prime95 Blend test or the FFT test?? If not please do run the Blend test so and post your experiences...
Hope to hear from you soon,
MADMAX23
chinkgai
3,904
thanks for the compliments madmax, i run a custom test with the exact same parameters as the blend test except for one thing, which is the size in MB. i limit each instance of my prime to 450 MB totalling about a gig but not quite a gig to avoid the page file bug of prime.
to run a custom with the same parameters as the blend, all you have to do is select blend first and you'll see that even though custom is not actually selected yet, the parameters are reflected in the custom parameters section. then all you have to do is select custom, then change the size in MB. keep up the good work max.
stevty2889
7,036
8
Got my A64 X2 4200+ today. Not hooked up to the network yet, so no screeen shot for now, 44170, stock speed(2.2ghz) 1024mb of Ram(2x512mb PQI turbo) 3-3-3-8. Can't believe how cool this thing runs, 35c idle, 44c max with 2 instances of prime95 small FTT running, stock heatsink and thermal pad. I'm impressed, this is my first AMD chip since the K6-2.
chinkgai
3,904
if and when u overclock, you'll be quick to see that these things run far hotter than the other a64's at the same voltage
but, u said its ur first amd since the k6, lol, so you're gona be comparing it to intels, which does make this thing seem cool ;)
StrangerGuy
8,443
124
Score: 16190
Athlon XP 1700+ Tbred B @ 1833MHz
Abit NF7-S
Dual Channel 2x 512MB PC2700, 2.5-3-3-7
Just for kicks I'll add a score for my P3 666MHz later. ;)
Zebo
39,398
19
Don't worry AMD starts ramping up like crazy after about 2.6... Just like pressy's do around 3.3. Sure at 2.2 they barley use any power ~60W!!! But at 2.6 ~130W!!!!
TStep
2,460
10
Just thought I'd throw in results from another lower powered system:
Mark: 17490
ALU: 6296
FPU: 8137
MEM: 3057
XP @ 2000 (12x167), Epox 8RGA+, PC2700 @ 167 2.5-3-3-7 DC (480 system, 32 IGP)
Duvie
16,215
Here is my finalized tweaked 2596mhz (11x236) setup....
The A64tweaker looks hosed on ram timings but I am using the 250 divider of the MSI Neo2 bios...calculated ram timngs are...
11/(250/200)=8.8...rounded up to 9 then divide into 2596 = 288.44 or 576ddr
My ram is running 2.85v but is rated as 2.5-3-3-7 for 550ddr. I am running cas 3-4-4-10 at this test...
56472
MADMAX23
527
Not at all chinkgai!!
Yes, I already knew how to use the custom mode in Prime95....
Scores updated guys....Duvie strikes hard again...!!!!
I've been very busy these last 2 days...sorry for not updating the scores earlier....
Have a nice day guys!!
Velk
734
new results for me from the 4400+
i got it prime stable at 2806, and i think i can get it prime stable at 2882 also, but i havent had time to run it more than a few hours at that speed. anyways here are the results with it at 2806:
dual prime torture test shot
Heat high 98C ? :shocked:
chinkgai
3,904
dont be silly ;)
at 2806, the high/load temp is 38c
the readings on my mbm "jumps" sporadically...it'll read 38c, then jump to some weird degree, then go back to normal on the next refresh
it does this for every reading, even voltages
yes i can bench at 2925, every bench, but not prime stable...i just get bsods after a certain voltage
MADMAX23
527
Scores up to date....
Chinkgai...really nice job with that 4400+!!!
Sorry guys...but I've been very busy thse days...
Diogenes2
2,151
Great chip! What are the stepping codes on that thing? Where did you buy?
My 4200 seems to be peaked at 2550...
chinkgai
3,904
stepping is 0524 rpmw
your peak is most likely heat limited cuz these fawkers get crazy hot
GuitarDaddy
11,465
dont be silly ;)
I wouldn't believe that reading of 38c load for a second. There is no way, unless your in Siberia with all the windows and the case open :) Somewhere in the 50's would be about right with highend air or water at those speeds.
chinkgai
3,904
with the exact same setup, and a slk948u i get near 60c with only about 1.5ish volts (then bsod)
the temp maybe not be 100 percent accurate since its mobo readings but its not toooo far off
i have a bix3 with 3 120mm fans and the cpu is the only thing in the loop
tdx block, mcp655
air coming out of the radiator is not even slightly warm
from what i read at xtremesystems, my wc setup is way overkill for just one cpu
its not 50s, trust me. i've felt the slk948 when it got in the 50s. nothing gets near that hot with the current setup.
edit: ambient is about 25-27c maybe 23-24c at night
