CrystalMark 2004 Competition! Stress your System!
chinkgai
3,904
oh and with my old 4200+ i was gettin 43-44 load
and when i crank up the voltage even more, i get 42-43 load with the 4400+ and the air coming out becomes slightly, very slightly warm, so i know the temp sensor isnt "broken" since i've changed from air to water
mwmorph
8,877
why is my cpu listed asa 3300+ paris? My AMD64 is detected to have 64bit extensions so shouldnt it be a 3300+ AMD64? (besides, it says athalon 64 on the heatspreader.)
btw, it's S753 s it's 1 channel ram.
ElTorrente
Banned
Aug 16, 2005
483
Here's ya go:
60895
Looks like the second best overall - I'm proud of my little rig. :D If I had a 1gb set of RAM instead of 2- I would probably make it to #1 in this contest, since I could probably drop my timings down a bit. My RAM is running great though- no complaints.
I wish we could include HDD scores in the contest.. I'd be #1 for sure.. :)
rise
9,116
46
thats a nice score. i still have a little room left but certainly won't hit 60k. :)
chinkgai
3,904
Originally posted by: ElTorrente
Here's ya go:
60895
you wouldnt be number one, i can run this at 2.9ghz...same timings...muahahah...jes didnt ;P
Gronich
145
Originally posted by: chinkgai
new results for me from the 4400+
i got it prime stable at 2806, and i think i can get it prime stable at 2882 also, but i havent had time to run it more than a few hours at that speed. anyways here are the results with it at 2806:
crystalmark at 62211
and
dual prime torture test shot
thanks max
Can you explain why your Fibonacci figure is 20% higher than everybody when all your other figures tally with my system at the same speed?
chinkgai
3,904
i have a 4400+, which means 2x your cache
my ram is running at a higher fsb (255 vs ur 233) and tighter timings (2-2-2 vs ur 2.5-2-2)
Ronin
4,563
server.counter-strike.net
I couldn't handle not being in the Top 10, so... :p
49740
Limiting factors right now are the motherboard (it's an Xpress 200 mobo from MSI with extremely limited OCing options). RAM is at 2-3-3-7-1T, 210MHz. CPU @ 2520MHz
jim1976
2,704
Not bad at all, considering I have my memory(Mushkin Redline xp3500) running at 5/6 225(2-2-2-5) and not 1:1 (I could do 256 @ 2-2-2-5 with my Winchester 3200+) :( Dunno maybe it's the mem controller of my Toledo). Maybe Chingai or someone else can help me with this?
I can also ran @2.8 but I need to prime test it first and also I don't want to go at a higher vcore for now , so I kept my scores at 2.7(10x270).But I think my cpu can go much higher than what I am running now(2.9 at least)
Think I am on the top10 right? :D
Rig in sig
MADMAX23
527
Scores updated guys!!
I didn't think this thread was still in your minds...I'm happy to see that though!!
Have a nice day!!
chinkgai
3,904
Originally posted by: jim1976
58067
Rig in sig
so...whats ur question?
chinkgai
3,904
49740
ur not! :(
jim1976
2,704
Thanks for taking the time m8 to ask ;)
My problem is this:
Not bad at all, considering I have my memory(Mushkin Redline xp3500) running at 5/6 225(2-2-2-5) and not 1:1 (I could do 256 @ 2-2-2-5 with my Winchester 3200+) Dunno maybe it's the mem controller of my Toledo).
I mean what can cause my sticks to ran at such low fsb considering that I ran it in the past at 255-256 at 2-2-2-5 with my monster at o/c Winnie.
chinkgai
3,904
whats ur max for ur 4400 (fsb)?
basically...my point is if u are trying to run 11x255 (or 256) thats 2806 (or 2816)
at this speed, you probably need a pretty good voltage bump. x2's get real hot after a certain point and also lose stability cuz it gets too hot. if you dont have sufficient cooling, try 255 (or 256) with a lower multiplier...like 9 or 10
this takes the cpu out of the equation and leaves only the ram
i highly doubt ur cpu can run 2700mhz but wont go 250ish fsb, altho that MAY be possible. i just doubt thats the case. also, it might be harder to get the same results from single core to dual core...but u should still be within a few mhz
when i went from sckt 754 to 939...i lost like four mhz peak...ur going from single to dual core...so that may be a factor
jim1976
2,704
Well I didn't explain it thorougly. I meant what ram is capable of. My Toledo can go @2.8 with 10x280 or 11x255 w/o issues.(just haven't primed it yet) But I have to use a very low divider to ran with 2-2-2-5 as I want at 2.8GHz. I can't seem to get my ram to ran @ more than 227 with 2-2-2-5, while this wasn't the case by far with my winnie. I have a XP-90c for cooling with a tt cpu fan running@4300rpm. Idle temp is 39-40c and 55-56 max at load.
I mean why ram can't go higher than 227 with 2-2-2-5? We are not talkin about a small difference we are talkin about at least 25Mhz (255 2-2-2-5) compared to what they ran with my winnie.
