Crysis 3 CPU performance test
The i3 is simply destroyed by the FX 4300 and the much superior FX 6300, i'd like to see an A10 5800, i3s direct competitor, in these benches.
Wow look at the 2C/4T i3 😳
It just shows that recommending i3 for 2013+ "low budget gamer rigs" is getting absurd. This thing should not be recommended to people who want to game on the budget and want intel cpu inside. Lowest QC i5 at the minimum should be recommended and this trend of optimizing newer games for multicore is just starting.
that's only one game, I can provide you some tests showing some new games where the 6300 is as fast or slower than the i3, but sure the 6300 for $10 more is looking like a much nicer choice at the moment.
5800 is slower than the 4300, faster than the 740k
I noticed it 🙂. Check PCGH GPU test for Crysis 3 😉. Too bad resolutions in two reviews don't match so we can't compare Titan's score from low resolution(CPU benchmark) to the numbers from other one.
Glad I went with a 3770k! I'll have to reinstall my Radeon 5850 though when I play it.
I realized that I hardly game anymore. My fiance uses my computer way, way more than I do. So I uninstalled the 5850 and went with the HD4000. For what I have been playing, the HD4000 actually doesn't do too bad of a job of delivering.
She's said on a few occasions that my computer is really, really fast lol.
Considering a 7970 can only get 37 fps @ 1080 /w 4xMSAA, and 690 only 58, I'm not really sure you should be using this as an example.
12% more performance at stock for 33% more $, the case is not strong in this one.
Drop your MSAA to 2X or use SMAA instead. From what I've been reading, once you get to 4xMSAA, Crysis 3 REALLY starts kicking the GPU's ass. Even in CF/SLI configurations.
I hope you know how to turn sliders down, looks like this might be the game that makes me pull out my 560TI and get something beefier, a 5850 is going to get hammered by comparison.
1080P medium should work well enough for a 5850, no need to upgrade.
It seems in this game Intel 8T is not scaling as well as AMD 8 cores given that FX-8350 beats 3770K by a large margin in performance per dollar.
I wonder if the game is not as well coded for HT as it is for AMD cores. Otherwise Intel need to considering bringing hexacore down to mainstream to maintain its gaming edge in the future.
It seems in this game Intel 8T is not scaling as well as AMD 8 cores given that FX-8350 beats 3770K by a large margin.
I agree Intel should bring out a mainstream hex core, but I don't see where you are saying the 8350 beats 3770k by a large margin. The difference is actually very small. I do think Intel is relying too much on high IP and hyper threading though. They really need to increase clockspeeds and bring out a mainstream hex core.
I call 2 FPS a large margin partially because the difference in cost, so I should rephrased that as "a large margin in performance/$" as some would consider a $300+ CPU losing to a competitor's $200 chip by any margin an embarrassing defeat.
Umm, 12% more performance for $100. I think **MANY** people would be willing to cough up $100 for 12%. FFS Nvidia is selling their 'real' 680s as a Titan for like $1,000 without much outcry when prev gen was $500.
There is considerable outcry over the price 😛
Many did, but that's not 12% from just HT, it's also from more clock speed. Which from what I've seen is the opposite of what happens once we overclock. Meaning on the same cooling solution a non HT i5 or disabled i7 will hit higher clocks at the same voltage and heat levels as one with HT enabled.
If you wanna go ultra detail on Crysis 3 then you need a 570 or 670
Same with BF3. If you put ultra high settings it will knock the framerate by half if not more.
Id like to see something like this with video card included. gl
I cried about it before I bought my 670's and we all knew this was going to happen with nvidia charging $500 for the mid range. Anyone who didn't see it coming was in denial. What I didn't see though was the stupinsane (yes, thats a word. I just invented it) $1000 price. I guessed about $700.
I think the i3 is a bottleneck period for a GTX 690 regardless of whether Crysis 3 is being benchmarked. It's already been established a long time ago that when using SLI or CF it requires at least 4 cores or more.
how much overclocking headroom does the fx-8350 have above 4.0 ghz typically?
Given how much headroom you have with a 2500k and 2600k you miss some of the picture just looking at the stock frequencies. Good showing from AMD though to be in the neighborhood, even if they have to boost stock frequency and TDP to get there. That has to be encouraging for future games which invariably are going to be making use of more cores.
i see ppl hitting 5GHz pretty easily with good Cooling
As far as I understood the author of PCGHs benchmark, it's the calculations for the grass in Crysis 3, that makes so good use of multithreading.
I just watched the video on their site. That bench sequence doest look any good.
I wonder what kind of work-load a big firefight would put on the CPU. Video game-developers needs to put back demo recording and timedemo.
+1 for the full multicore support. performance reallie shines when all core are running at full speed - especially on a slower ipc amd.
+1 for full HT support. added 6fps. i5 to i7
now only
if other games would fully support multicore.
and only
if intel had an affordable 8 core. (pretty sad to see amd 8 core slightly pass intel 4 core)
and only
if nvidia titan was $600. 🙄
