crt1530's Training Journal
crt1530
3,194
Sheiko #32 Week 1 Day 3
Squat
235x3x1
280x3x2
325x3x2
350x2x4
Bench Press
145x3x1
175x3x2
200x3x6
Chin-up
BW+15x5x5
Press
100x5x5
Good Morning
140x5x5
Hanging Leg Raise
BWx12x2
BWx7/3/2
Notes
No belt or knee sleeves. Total time ~75 minutes. Good mornings on one minute intervals, two minute intervals on everything else. I was feeling tired today. The bench sets felt hard. My will/energy ran out on the last set of hanging leg raises. I had at least two more reps, but I gave up at seven.
z0mb13
18,106
Pardon my stupidity but what does this mean??
Bench Press
125x5x1
150x4x2
175x3x2
185x3x5
I know the left three digits are weights (pounds), but what do the remaining numbers mean?
crt1530
3,194
Weight x reps x sets.
125x5x1 = one set of five repetitions with 125lbs.
z0mb13
18,106
so in that bench press example you go through all that in one exercise?
crt1530
3,194
A repetition is the completion of one full movement of an exercise (e.g. a bench repetition starts and finishes with your arms fully extended and locked out). A set is a group of repetitions performed without racking the bar.
In the example you copied,
Bench Press
125x5x1
150x4x2
175x3x2
185x3x5
I performed 10 sets of bench press. The first set was five repetitions of 125lbs. The second and third sets were four repetitions with 150lbs. The final five sets each had three repetitions of 185lbs. For bench press, I generally start sets on two minute intervals, so this portion of the training session would've taken about 20 minutes.
crt1530
3,194
Sheiko #32 Week 2 Day 1
Squat
235x3x1
280x3x2
325x3x2
375x2x4
Bench Press
135x3x1
160x3x1
185x3x2
215x3x5
Pull-up
BW+15x5x5
Squat
255x3x1
305x3x2
350x3x4
Press
100x5x5
Hanging Leg Raise
BWx12x3
Notes
~80 minutes. No belt or knee sleeves. All sets done on two minute intervals (some warmups <2min). Energy was good today.
crt1530
3,194
Sheiko #32 Week 2 Day 2
Deadlift to Knees
265x3x1
320x2x2
345x2x2
370x1x3
Bench Press
135x3x1
160x3x1
185x3x2
215x3x2
225x2x3
Deadlift
265x3x1
320x3x1
370x3x2
425x3x5
Hanging Leg Raise
BWx12x3
Notes
~75 min. Grip was good. I've been using my grippers consistently (haven't logged my training w/ them) and I think they've helped to toughen my hands.
crt1530
3,194
Captains of Crush Hand Grippers. The deadlift to knees is supposed to train your form for the first part of the pull. I'm not entirely sold on the idea, but I just decided to do the program as written yesterday instead of leaving them out or subbing another lift.
crt1530
3,194
Sheiko #32 Week 2 Day 3
Bench Press
135x3x1
160x3x1
185x3x2
215x3x5
Squat
235x3x1
280x3x2
325x3x2
375x3x6
Bench Press
135x4x1
160x4x1
185x4x4
Chin-up
BW+15x5x5
Notes
My back was pretty stiff and fatigued from deadlift on Wednesday, so I used a belt for the 325 and 375lb squat sets. My right shoulder felt a bit funky...I slept on that side last night.
crt1530
3,194
Sheiko #32 Week 3 Day 1
Squat
235x3x1
280x3x1
325x3x2
375x2x5
Bench Press
135x3x1
160x3x1
185x3x2
215x2x3
225x1x3
Pull-up
BW+15x5x5
Hanging Leg Raise
BWx12x3
Notes
Back still slightly tight. Need to focus on the deadlift form and work on keeping my hips down.
Mar 22, 2002
10,483
32
Quick question: what are your stats? Height, weight, etc? I looked in the OP, but I couldn't find it. It seems that your progression is going pretty well and it's always nice to see that :) Just started my journal so I can actually track it in an organized fashion. Good luck.
crt1530
3,194
I'm 25, 5'8" and weigh 198lbs. I weighed 155 when I was your age.
crt1530
3,194
Originally posted by: paulxcook
Good squatting. Do you feel like your bench is catching up at all?
Meh. I don't think I'd say "catching up," but it's improving. I could probably improve it a lot faster if I took it easy on the lower body stuff and devoted all of my recovery ability to upper body, but that wouldn't help my total body strength and powerlifting total.
I'd never really done barbell bench press until the start of 2007. The most I had ever bench pressed this time last year was 200 for a touch and go rep. Now I've done 255 for a paused rep and think I should be able to do 260/265 paused. I'm just going to keep plugging along and try to add 5lbs/month for as long as I can.
paulxcook
4,277
For only starting bench press a year ago 260 seems pretty good. Granted you already had a good base of strength when you started. In the powerlifting competitions you participate in, does bench just count for less, or do you care about it less, or what? I seem to remember you doing bench at some point in your APA video.
crt1530
3,194
Your "score" in powerlifting is simply the total of your best single rep max attempt in the squat, bench press, and deadlift. Since the squat and deadlift allow you to lift more weight and utilize mostly the same muscle groups, it doesn't make sense to eschew lower body work in the hopes of increasing the smallest of the three lifts.
crt1530
3,194
Sheiko #32 Week 3 Day 2
Bench Press
135x3x1
160x3x1
185x3x2
215x2x5
Chin-up
BWx12,10,8
Back Extension
BWx20x3
Notes
Meh. Back is still tight, so I did some high rep back extensions to get some blood pumping through the muscles instead of the deadlifts that were on the schedule.
Mar 22, 2002
10,483
32
Ah, it's sad to hear that your back is messed with. Maybe take a warm bath and get someone to give it a bit of a massage? It's a good call on your part though to cut out the deadlifts. Listening to one's body can sometimes be the hardest part with lifting.
spamsk8r
1,787
Those are definitely some impressive numbers. I just got back into weight lifting myself, and my max deadlift is 295, so you putting up almost double that is insane. This training routine looks brutal, maybe I'll try something similar once I finish cutting fat :)
crt1530
3,194
Sheiko #32 Week 3 Day 3
Squat
235x3x1
285x3x2
325x3x2
350x2x3
Bench Press
135x3x1
160x3x1
185x3x2
200x2x4
Notes
Deloads are boring.
paulxcook
4,277
How long til you get back to "normal"? Was this deload part of the Sheiko program, or are you trying to help your lower back recover some more?
crt1530
3,194
The deload is part of the program and is intended to prepare me for maxing out again at the end of this week. This is the last week of the sixteen week program. I haven't decided yet if I'm going to just run it again or try something different.
paulxcook
4,277
It might be cool to run it again and see where you are each week compared to the first time you tried it. Then again you could do that after you complete something else and probably really see a difference.
