Originally posted by: Yoxxy
I had good luck with those G.Skill 4-4-4-12 on a DS3. Ran upto 850 on 4-4-4-12 24 hours orthos stable. 425x8.
Originally posted by: Sniper82
Which should I go with and is more likely to work on a DS3 and o/c the best?
http://www.newegg.com/Product/Product.asp?Item=N82E16820144028
http://www.newegg.com/Product/Product.asp?Item=N82E16820231098
http://www.newegg.com/Product/Product.asp?Item=N82E16820231087
Geil is Micron D9 the other is either Elpida or Promos. the Geil will overclock better
According to this thread the Geil is Elpida? Or I maybe I am just confused?
Geil ultra = Micron 100% all the time
k thx should this work np in a DS3?
reread my post I edited it a bit. I don't trust newegg to give accurate information because you don't know the part number so it's hard to say whether you're buying the D9 Ultras or not.
Keeping all this in mine lets assume it's elpida. You have a chance to get promos with the cas4 G.Skill which is alot better than elpida.
Right, that's why you can always spend a little more and get Crucial or Team or G.Skill HZ, or Buffalo Firestix, or a vast selection of other choices that do guarantee Micron D9 ICs. They are more expensive like I said.
Thx for the help. I do realize D9's are suppose to be good/the best but I have to get the budget stuff. To be honest I just need some 800mhz memory. I was just wanting to get the budget set thats likely to give me the better o/c.
Originally posted by: Roguestar
Too bad all the Corsair 10th Anniversary are sold out then. :laugh:
CLICK ME
They have the Geil Ultra 800+ in stock for $230.14
These are handpicked Micron D9GMH rated at DDR2-800 3-3-3-8
Call to verify stock and specify the product number GX21GB6400PDC
Although this is a 1GB kit it's the best I could find for this type of memory. Maybe it's all out of stock.
note: the 2GB kit of this stuff sells for $460
CLICK ME
That sounds real expensive for the 1GB kit. Couldn't you go a guaranteed Micron 2GB kit like Patriot? (same price AFTER $35 rebate)?
I must be missing something.
CLICK ME
Patriot IS NOT Micron any more. Do also realize that this memory is 100% hand picked. Yu're paying for the best of the best of each IC in each stick. Being rated at cas3 means alot too.
