- Sep 28, 2005
- 21,074
- 3,577
- 126
Originally posted by: Narse
I am going to be doing the same thing in the same case soon myself, maybe you will have some ideas as to where to place things.
narse i havent forgotten about you.
im just figuring out a way to install a radiator inside your case. LOL..
the 900 wasnt designed for H2O purpose. :X :\
I don't mind mounting the radiator outside the case, I have been lookin at the swifttec kits they look simple but I am not sure how they perform.
Also I do plan to pick up the 1200 if Antec ever releases it. I think it is going to have an option to purchase it with a radiator mounted at the top with to 200mm fan.
mmmm then your budget is doable. i thought u asked for an all internal build.
