Considering going water cooling
EvilSponge
747
Well I agree to a point but when you tring to squeeze a processor for all it's got advanced cooling does play a factor as an example my TRUE allows me to runn my q6600 @ 3.6ghz loaded temps @ 61-63c if I bump things up to 3.7ghz temps climb 5c!
-sponge
BTW AL Gore is a fraud/opportunist... nothing against 30in monitors though :)
0roo0roo
64,795
84
oh i know you can squeeze more, i'm just saying that its not like before when we all had single core processors and you could really feel the difference. now even base line budget processors are fast for most desktop tasks and multitasking. and video card matters more than cpu.... so the wow has sorta gone out of it. bigger screen is where its at! and no, i dont like gore either, but thats still a sweet setup!
aigomorla
21,073
3,576
Its not a triple, but a double 24'
http://i125.photobucket.com/al...aigomorla/IMG_0829.jpg
Also you cant get these clocks on air 24/7:
http://i125.photobucket.com/al...3/aigomorla/Wprime.jpg
and i used to watercool for the bling and performance. Now i watercool for the silence and because i cant tollerate the temps which are associated with air.
While air loads at 70-75C, i'll load at 40-45C at a clock roughly 200-300 mhz higher on all 4 cores. And yes thats quite a bit of performance increase.
If you plan water out correctly, and grab enough budget, you cant compare the two. Its like comparing a camry with a lexus IS F. You bring out phase onto these girls, and its seriously OMGWTFBBQ GG NO RE, And every other thing a fob says to you when he rapes you in warcraft3! I see most phased QX sitting at around 4.5-4.6ghz which is sub 10sec super pi 1m territory.
EvilSponge
747
OMG those temps are sick!. Yeah I'm all steam ahead for WC one peice at as time BTW I think I have a way to use the large three fan radiator will need to be mounted outside my case though. Thanks again aigomorla I'll be talking to you for advise once I have all my parts collected BTW HOW many feet of tubing do you think would be prudent to buy?
-sponge
aigomorla
21,073
3,576
-sponge
for newbies i recomend somewhere between 10-15 feet.
This accounts for the OOOPS factor.
EvilSponge
747
Excellent well I'm for sure a WC newbie so 15ft it is. Also you say zipties are fine to use opposed to metal worm drive clamps? Also please recomend NB chip water block thanks
-sponge
What radiator are you using for your 45nm chip?
Rubycon
Madame President
Aug 10, 2005
17,768
485
Measure twice cut once. If you're paranoid try it with string first. ;)
aigomorla
21,073
3,576
Ah great idea Ruby thanks. Any opinions on min bend radius?
-sponge
get coils for this. Koolance makes some nice ones in different unique colors. Get the one with the 5/8OD
As for tubing get masterkleer 7/16ID 5/8OD.
http://www.jab-tech.com/Master...ID-5-8-OD-pr-3079.html
As you see when you buy 10feet or more its .49 cents per feet. So its not big money out of pocket.
And ruby even if you messure twice and cut once, an opps can happen. Like, OPPS why did i loop it this way instead of that way oops. :X
Or the infamous OOPS not this one, i ment that one, aww crap now its stuck can cant be pulled out conventionally. :p
Rubycon
Madame President
Aug 10, 2005
17,768
485
-sponge
Angle of Bend/360*2pr= min tubing length to make bend.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Sorry about that! With plastic tubing you do have mercy as if it kinks you don't damage it. But you do want to make the bends as gradual as possible. You can use elbow fittings but these will add roughly the equivalent of a full foot of head pressure (lift) to the system!
EvilSponge
747
Thanks I'm going to start with the reservior this month. Also what water block for the north bridge?
-sponge
aigomorla
21,073
3,576
XSPC - Acrylic Reservoir for Laing DDC ordered!
-sponge
:D its all coming together slowly but surely.
EvilSponge
747
LOL yeah now I'll have to see how I cram all this stuff into my antec900
I'll put up my water cooling page soon to document the progress
-sponge
Narse
Moderator<br>Computer Help
Moderator
Mar 14, 2000
3,826
I am going to be doing the same thing in the same case soon myself, maybe you will have some ideas as to where to place things.
aigomorla
21,073
3,576
narse i havent forgotten about you.
im just figuring out a way to install a radiator inside your case. LOL..
the 900 wasnt designed for H2O purpose. :X :\
Narse
Moderator
Mar 14, 2000
3,826
I don't mind mounting the radiator outside the case, I have been lookin at the swifttec kits they look simple but I am not sure how they perform.
Also I do plan to pick up the 1200 if Antec ever releases it. I think it is going to have an option to purchase it with a radiator mounted at the top with to 200mm fan.
