Vic
Originally posted by: MercenaryForHire
Originally posted by: ElFenix
screw the car, i'm taking the girl
I'd rather screw the girl and take the car, but whatever floats your boat. 😕
- M4H
I already own that car.
- M4H
Originally posted by: Ragnarok2
Since they're pretty cheap and and actually increase the HP somewhat I'm thinking about putting in a cold air intake in my chrysler.
The question is, can I use the factory air intake tube and just buy a coupler and filter, or do I have to get a new intake tube as well? Thanks a whole bunch!
- M4H
I understand that a CAI won't make my Chrysler sedan gain lots of HP, but hey, it still does something, and it does look nice under the hood, which increases the resell value even if by a little. They're pretty cheap nowadays anyway, so why not get one eh? Isn't it a better idea to just get a CAI rather than go and buy a $20 paper filter for the factory intake?
- M4H
So you're saying you'd rather the former of the two options? 😕
- M4H
- M4H
- M4H
I can afford the car, but not the chick.
- M4H
- M4H
Alright you guys convinced me not to buy a CAI. I went to PepBoys and the tubing itself was $50 plus the filter and coupler, so I was like screw it, I'll just get a good filter for my factory intake.
Negative. New car warranties can never be voided by modification (except to the odometer), however warranty claims directly related to the modified parts can be denied on a case-by-case basis.Originally posted by: thescreensavers
viods your warranty
Shut up! SHUT UP! *bang*Originally posted by: Vic
Originally posted by: Zenmervolt
HAHAHAHAHAHAHAHAHAHA.....Originally posted by: Aikouka
Colder air compresses better, which means it provides less resistance to the push of the piston, which means that there's less energy being wasted on that compression stroke.
Wow, that's one of the funniest things I've heard in a long, long time. And I've heard some whoppers from people who think they know about cars.
Colder air is denser. This makes it slightly more difficult to compress (not enough to make any real-world difference at all though).
The power increase from colder air is due to the increased density. Because the air is denser, it contains more oxygen per given unit volume. More oxygen allows the engine to burn more fuel, which creates more power. This is one of the reasons that cars typically get poorer mileage in the winter. The colder, denser air causes the FI system to compensate for the extra oxygen by injecting more fuel.
Whoever told you that "colder air compresses better" should be banned from even touching a car as they obviously have no clue.
ZV
WARNING! DANGER TO MANIFOLD!!
:laugh:
Even the filter is a waste of money. Seriously.
The HP gain is even MORE negligible, and cleaning it is a royal pain in the ass. It will take YEARS for you to make up the difference in cost between using paper. If you have never cleaned an oil based filter before, it might sound like nothing, but your car will be undrivable for hours, and it's messy, and easy to screw up. Over oil the filter and you will foul up your MAF.
The only thing you should consider doing is changing your air filter more often, thats it. Want more throttle response? Tighten your throttle cable and attach lead to the soles of your shoes.
Is your car an auto or manual?
Auto
Just put your car in 3 instead of OD, if you want a little more fun.
Would that actually do anything?
Originally posted by: LS20
****** subwoofer = bad
aftermarket exhausts = bad
intakes on 4 bangers = low-key and pleasant
