exdeath
Originally posted by: Aikouka
Originally posted by: makken
I think you're going a little too technical.
warmer air = less dense = less (actual) oxygen.
On almost any modern car, the ECU determines how much gasoline actually enters the cylinder. The ECU is programmed to give just enough gas for a perfect burn - ie. all of the oxygen and gasoline is combusted. (actually, I think they're tuned to run a bit on the lean side, but dont' quote me on that) Warmer air would have less oxygen per unit volume, such that the ECU will reduce the amount of gasoline it puts in.
At least that's my reasoning for it.
Yes, you're right, but we're both making the same point, I'm just saying it in an unorthodox way that some people (like the guy who I quoted below) will not understand. The ECU actually contains preprogrammed O2:Fuel Ratios that when the O2 sensor passes the amount of O2 that it finds in the intake, it sends the electric signal to the F.I.'s and if all is timed correctly, we'll get our big bang when the sparks chime 😉.
Originally posted by: Zenmervolt
HAHAHAHAHAHAHAHAHAHA.....
Wow, that's one of the funniest things I've heard in a long, long time. And I've heard some whoppers from people who think they know about cars.
Colder air is denser. This makes it slightly more difficult to compress (not enough to make any real-world difference at all though).
The power increase from colder air is due to the increased density. Because the air is denser, it contains more oxygen per given unit volume. More oxygen allows the engine to burn more fuel, which creates more power. This is one of the reasons that cars typically get poorer mileage in the winter. The colder, denser air causes the FI system to compensate for the extra oxygen by injecting more fuel.
ZV
Congratulations for telling me what I already know. Your argument of which one is harder to compress actually depends on the volume being the same, where my point was on the amount of oxygen present being the same, which makes the volume of the colder air lower, because... it's already "compressed" to a degree (the particles being closer together). You essentially said the same thing as me, but I guess it's my fault for not being completely specific in stating volume vs oxygen content. When it comes to engines, yes they do pull in the same amount of volume (via the vacuum created during the intake phase of the piston) regardless of whether the air is hot or cold, so my original comment is only theoretical and doesn't apply to true "engine physics." Also, you forgot to include one comment against me: NA cars typically have higher compression ratios than forced compression.
Personally, I know all about the concepts of using colder air because it allows higher densities. Intercoolers, devices to cool the air that is sent through the intake, typically (well, I've never seen them featured without...) featured after turbochargers, because turbos have that tiny problem of compacting air, but also heating it up.
My fault for not being clear, but your fault for acting like an ass.
No.
The intercooler drops the incoming temperature by x degrees. If you reduce the intake temperature by y, it combines with the intercooler's temperature drop to give a total drop of x+y degrees.
Now, will that give a significant difference? No because on a high power engine the 3-5 hp that a CAI can add (best case) will be something like a 1-2% increase, which won't even be enough to feel.
So it's "useless" from a standpoint of getting meaningful performance increase (you'd be better served by simply getting more airflow to the intercooler) but it still provides the same benefit as it does with a naturally aspirated engine.
ZV
You forgot a variable in yer equation there... air temperature being increased by turbocharger compression as you don't find too many intercoolers on cars that don't have forced compression systems.
Originally posted by: MercenaryForHire
I'm going to guess Talon TSI for the former, then when he put a leash on his crank and took it for a nice long walk, he got a 2.4L mid-size, like a Sebring.
Not meant to insult anyone, just taking random guesses for my own amusement. 😀
- M4H
1991 Eagle Talon TSi AWD with a JDM low-mileage evo3 4G63T installed (by me). The engine is still working fine although I don't drive the car. The reason being that the clutch glazed over while driving it once and I replaced it, but my father, who helped me with certain aspects such as technique on putting larger parts in, etc, died before I had a chance to put the Transmission back on. Also, the fact that I still don't know what caused the clutch the glaze over and how other things were going wrong on the car... it was a bit of a downer for me and I somewhat lost interest. Other things being how the tach just died all of a sudden... before it died, it'd just randomly drop to 0 and then resume proper working order. I replaced a leaky cap on the ECU, checked the ignition coil (replaced it actually) and the tach would never work. My dad tried to tell me that I didn't need it, so I told him to try driving it without one. Now, he drove manual cars for about 20 years with no problem. After he tried it, he came back and told me, "Yeah, it'd be nicer to have a tach with that car."
I don't have a Sebring though, I have a 2002 Stratus SE and yes, it is a 2.4L 😛.
The O2 only works in closed loop mode at idle for emissions at stop lights, parking, etc. It's completely ignored in open loop mode under WOT conditions.
