Maybe more 7000 series owners need to test and give input on these,i found them to be incredibly stable with absolutely no problems thus far.
I take it performance drivers are waiting for Kepler or GCN is a b**** to code for![]()
7950 owner here.
My only issue with these drivers is my idle temp seems to be slightly higher now.
Before 12.2 my Sapphire 7950 OC would idle around 28-29C. After, 30-33C.
Oh I guess one more issue is my screen flickers a few times when loading a game, but once the game loads and Im in menus/game play, everything runs fine.
I noticed this also, I thought I downloaded a beta version at first. These new drivers are terrible though. I am downloading 12.1 right now.Anyone notice in CCC 12.2WHQL report as 12.3? Odd.
Ok, so what's this now?
This morning I turned on my PC before i went to work and I got the message "you have no display driver installed. Please install the appropriate driver for your hardware".
Ok - fine. I downloaded 12.1 and re-installed it, thinking there must have been some sort of glitch.
So I get home tonight, start PC ........ Same message.
What's going on here?
Try uninstalling your drivers, restarting in Safe mode, run Driversweeper and remove everything but the 2 directories (your monitor profiles if you have multiple), then restart and install 12.2 or 12.1, whichever you want to use.
If that doesn't fix it you might want to RMA your card or your PSU.
Went back to rc11.. 12.2 crashed loading bf3 even when not overclocked.
Slightly better 3dmark on the 12.2 (9300). Compared to 8900 with the rc 11.
Despite my earlier post,i'm with the majority here,these drivers majorly suck.
My issues i thought that had disappeared being my core getting stuck at 501mhz half the time in a game and the hardlocks just randomly started to happen again out of the blue last night,ironically these drivers work at will,nothing more almost like a test of psychological torture.
Sadly rc11 is more stable then any of the 12 series for me,and the failure of ocing drivers,i can't even hold 1125 at stock on the core on rc11,where is the phucking win?:awe:
Flash or youtube throttles the GPU clock down, you probably had a browser window open...or WMP
