Wouldn't Seafoam work to hit the valve if the right kind were sprayed into a vacuum line? I'm not advising this, BTW, just food for thought.
I kinda assumed that I would need to get the engine in the vette walnut blasted eventually. Honestly though, I'll probably pick up a catch can and stick a scope down there periodically. If it gets bad that's an excuse to pull the heads and have them ported... which is an excuse to get a new cam... which is an excuse to get new valves and springs... which is an excuse... well it all ends up with a 427ci LT1 and lots of boost....
$500 seems very reasonable for blasting the intake valve area. It's not a hard procedure, just time consuming. I doubt that it would be very difficult to DIY if you had a media blaster. Shit I have a 50lb bag of walnut media in the basement (but it's larger stuff for tumbling not for blasting).
Have to pull off the intake manifold and all the crap connected to it.
It wouldn't help any as there isn't any way for seafoam to splash onto the intake valves.
I wonder if any of these issues will be covered under warranty, as there is literally zero preventative maintenance an owner could conceivably do to prevent this..
I dunno, I've had it clean some pretty gnarly looking stuff given enough time to soak in(diesel EGR passage in an euro intake most recently), the trick is, and the bottle used to say as much I think, that you basically have to choke the motor off with the stuff in order to completely soak into the carbon on the valves, then let it sit, then do it again to blow out the soaked (and in theory dissolved/loosened) crud. Preferably with hard, high RPM driving. I'd rather not put chunks of carbon like that through my motor personally, I've seen carbon pieces hard enough to bend valves. I'd also rather not put chunks of walnut through. Nothing that just blows some solvent across briefly is going to take off serious hard baked carbon, it's got to soak into it one way or another, or use mechanical removal. Wonder if some anti-stick coatings on the back of the valves would help? All of that carbon cleaning stuff works by dissolving the goo bonding the carbon together/to whatever it's attached to. I'd imagine regular treatments before it becomes so dense and packed would be helpful too. I've also used oven cleaner, the more environmentally un-friendly the better, to eat carbon.
I am left wondering why manufacturers would take a step backwards with a problematic system like DI. It seems like carbon build up is a drawback for this system.
If it's creating deposits from overlap in the combustion cycle then I wouldn't think driving hard would help much if any. In a variocam motor there might be less overlap at high RPM than low or vice versa but I don't see that being significant. Though thoroughly "using" a motor is always a good thing. 🙂
How is this problem avoided on diesel trucks? Direct injection has been commonplace on heavy trucks for a long time, and those trucks often go a million miles between major engine overhauls. Not to mention they routinely go 30,000 miles between oil changes.
I want to say that some DI engines *do* now spray fuel on the valves, as an "extra" injector of sorts? The ECM somehow figures out when it's appropriate, and maybe cuts the other one off at the time.
Theoretically the N55 engine has less trouble than the N54 as well, but time will tell. Not sure what BMW changed in this regard (if anything).
Follow my train of thought for a second please. The purpose of DI is to avoid the injection of fuel during the intake stroke. The absence of fuel during the compression stroke means there is no chance for detonation at higher compression ratios or during valve timings that are higher performance.
Like some Toyota engines, this Audi powerplant family uses both direct and port injection. Direct injection is used to stabilize the idle and in full-load situations, while the port injectors are put to work under partial loads, where Audi engineers say port injection is better at mixing the fuel and air, with less soot produced and reduced CO2 emissions compared to direct injection. Unlike the Toyota setup, this engine operates either as a port-injected engine or a direct-injected one, and never uses both injectors simultaneously. The third-generation EA888 is said to be about 11 pounds lighter than the second gen, despite the wealth of new features.
A new V-6 3.5-liter gasoline engine (2GR-FSE) uses a
newly developed stoichiometric direct injection system
with two fuel injectors in each cylinder (D-4S: Direct
injection 4-stroke gasoline engine system Superior
version). One is a direct injection injector generating a
dual-fan-shaped spray with wide dispersion, while the
other is a port injector. With this system, the engine
achieves a power level among the highest for production
engines of this displacement and a fuel economy rating
of 24mpg on the EPA cycle. Emissions are among the
lowest level for this class of sedans, meeting Ultra Low
Emission Vehicle standards (ULEV-II).
Under most conditions, DI injects during the intake stroke, this ensures full mixing of fuel and air - so called homogeneous charge. Typically, this will be slightly lean under moderate load, and very rich under high load to minimize detonation.
Ok so this is where my misunderstanding lies. I was thinking that gasoline DI injects like a diesel engine DI does
Could be worse..
no way that's real. that huge pile of coal? come on
