Thanx for clearing that up!!! I noticed during all my research that everybody keeps talking about their turbo,now i know why.My intake receives alot of carb cleaner!!! 🙂^ A catch can is not a universal benefit to all vehicles. It's for direct injection engines due to the fuel not flowing over the valves to keep them clean(er). You don't have that situation with a carb'd engine, just use carb cleaner every now and then to keep the carb clean.
My actual reason for installing one is because my breather has an excessive amount of oil coming out.Yesterday i removed valve cover because one reason for.that is possibly a blocked baffle on pcv side.Seems this is not the case,motor.probably worn.Baffled catch can after breather then? And from there to the back of the intake where the "hot air" nipple was connected to the original air filter unit? Or into the air pipe to which my cone filter is attatched?
