Can I let my DSL provider know that I'm using a router?
DannyLove
12,876
4
As a SBC customer that has called in about 10 times over the past 3 years for connection issues, I can safely say that having a router with their services means absolutely nothing to them. After a series of questions, the Rep actually asked me what my network looked like, I told him I have a router, brand name and model number. SBC doesn't care.
danny~!
GoodRevrnd
6,801
581
Originally posted by: poopygood
they might just say, we can't help you trouble-shoot problems if you have a router, contact the router's manufacturer. Plus they'll then just blame all your connection problems on the fact that you have a router.
Correct answer. Verizon did that to me.
allisolm
Administrator
Jan 2, 2001
25,325
4,991
they will not do troubleshooting for you if you tell them you have a router that you did not buy from them.
I have DSL through Sprint and they do troubleshoot for me with a router that I did not buy from them. With one problem they even took me through my router configuration screens to get to the item that had to be changed.
ChicagoNick
43
i probably should've mentioned that my advice was SBC specific for the OP.
allisolm
Administrator
Jan 2, 2001
25,325
4,991
Even SBC specific advice seems to vary.
DannyLove said "As a SBC customer that has called in about 10 times over the past 3 years for connection issues, I can safely say that having a router with their services means absolutely nothing to them. After a series of questions, the Rep actually asked me what my network looked like, I told him I have a router, brand name and model number. SBC doesn't care."
Doggiedog
12,780
Originally posted by: Argo
First I had it in connect on demand, max idle time 30 minutes. Then I changed to 24 hours. Then I changed it to keep alive, redial period 30 seconds. I think in that mode it never disconnects.
What router do you have ?
Linksys BEFSR41
Call Linksys and ask for help.
I had a problem with my connection just like you did with my Linksys and they helped me fix it.
Banned
Feb 17, 2003
1,948
Originally posted by: ChicagoNick
Originally posted by: Mak0602
DO NOT TELL THEM YOU HAVE A ROUTER. they will charge additional isp if you do. and yeah, you are probably far from them. whine to them and ask when speed will increase, then whine so more. :)
amazing the rumors that go around ;) this is true for a CABLE ISP but not SBC DSL.
then stop spreading rumors of your own.
cable companies don't care either
