Boeing problems...
Dec 10, 2005
29,752
15,370
Being a whistleblower is a lonely road. You're potentially setting your entire career on fire and taking steps that will isolate you completely from people you used to call colleagues. It's not surprising that someone could spiral into depression and kill themselves.
uallas5
1,682
1,966
Yesterday it was the Dreamliner's turn. A "technical problem" caused a Latam flight from Australia to New Zealand to suddenly lose altitude, 50 passengers and crew were injured. One of the pilot's reportedly told a passenger that all the controls "suddenly went dark."
One woman on the flight said she experienced a “quick little drop” during the flight.
“I used to be a flight attendant and this is the first time I’ve ever . . . the whole plane just froze,” she said.
After the flight landed, passenger Brian Jokat told CNN that he spoke to the pilot, who he said told him: "My gauges just kind of went blank on me."
Jokat told CNN that he had been sleeping when the plane "dropped something to the effect of 500 feet instantly."
Opening his eyes, he said he saw "various individuals at the top of the plane. Just stuck to the roof and then they fell to the floor."
"And then I just realized I'm not in a movie, this is actually for real," he said.
MrSquished
26,838
24,976
He literally just started giving his depositions, was in the midst of them really, and he was a whistleblower, means he did it willingly because he felt there was important, that really doesn't make any sense.
Dec 10, 2005
29,752
15,370
I don't have all the details of what happened to this person, but suicide isn't exactly a rational action either.
Puffnstuff
16,256
4,930
I listened to a former pilot this morning on the news and he made a good point that all of the United planes with issues either originated or terminated at the same SF airport.
Reactions: hal2kilo
UNCjigga
25,727
10,487
Sounds like a suicide to me but being a whistleblower can’t be easy—just imagine all the friends and greater community that could be impacted if the airline is forced to restructure or move manufacturing back to Seattle. I’m sure his emails/voicemails/social media weren’t always full of encouraging words.
hal2kilo
26,656
12,729
Was never confident about anything anymore when we did away with discreet switches and relied on computer interrupts to detect the switch closures, then determine what switch was pressed. Also, can't stand modes redefining what a switch does. That's my personal experience working with 3 generations of systems.
Reactions: [DHT]Osiris
Indus
16,601
11,410
From the interviews.. even the pilot was terrified. He said his instruments just went blank and then came back.. so sounds like a power outage and fly by wire was disengaged and then reengaged.
They seriously need to find out and eliminate the flaws. Boeing's had quite a few freaky incidents happen over the years.. MCAS recently and even the 767 there was an incident where the thrust reverser deployed in flight and killed everyone on board.
Zorba
15,613
11,256
Sounds like severe turbulence, not a mechanical issue, but we'll see what the investigation finds.
Zorba
15,613
11,256
He had just given his deposition to the Boeing Lawyers. Even if he was completely correct they probably beat the shit out of him.
He also maximized the utility of his suicide doing it the way he did.
Zorba
15,613
11,256
Would the instruments blank out during turbulence though? Assuming that snippet is correct.
No, but pilots already are bad sources of data, then filter that through a passenger and who knows if that actually happened. Lots of pilots claim stuff happened that didn't once the data was reviewed.
I was involved in an investigation were the aircraft went off the runway, neither pilot realized the airbrakes were never deployed. They announced to the aircraft that the brakes failed and they and no braking power. A similar conversation was caught on the cockpit voice recorder. They were convinced the plane was broken. What actually happened is without airbrakes, there is almost no weight on the tires so the antiskid system won't apply much power to prevent skidding. Just like ABS in a car on ice.
On the 787, there was an airworthiness directive (AD, which are required maintenance) that came out years ago that said the aircraft had to be rebooted every 20 days or the system could randomly reboot in flight. It's possible that Latam failed to do that. Not exactly sure what that would do in flight, but it probably runs through a built in test (BIT) check that moves flight controls.
Nov 17, 2019
13,458
7,907
Has the Pea&Nut gallery seen this?
Boeing overwrote surveillance footage of door plug repair, NTSB chair says
abcnews.go.com.ico
ABC|4 hours ago
Boeing overwrote surveillance footage from the repair facility where a door plug was reinstalled ahead of the blowout on an Alaska Airlines flight earlier this year.
manly
13,590
4,239
No better time for a smoke test than when cruising at 32k feet. 🤦‍♂️
