Boeing problems...
Zorba
15,613
11,256
I can only correct you on one thing, Zorba. FAA doesn't “approve" your MEL or your operating certificate, ie Part 91, 135, or 121. They “accept” it.
I’ve written, submitted, and had accepted at least four over my career. I’ve been retired for about 11 years now but I can't imagine that part of the FARs have changed.
Thanks, I typed accepted first, but then I thought it was approved. I haven't ever been directly involved in creating an MEL for an airline.
Reactions: iRONic
[DHT]Osiris
17,566
16,933
If you are referring to me I didn't know so I had to google. :colbert:
Sorry no, I meant whoever did the wrong with the acronyms. I find that when someone's performing an after action report and there's a lot of acronyms involved, it probably means someone skipped some steps.
Reactions: Drach
Drach
1,384
2,134
You're referring to safety wiring the bolts?
I would hope so.
Amateur road racing motorcycles we had a tech inspection for that.
Couldn't go to tech inspection with fairings on.
If the airline industry is more lax than amateur road racers ill never get on a plane again.
[DHT]Osiris
17,566
16,933
Yeah, sorry, I was always a few steps removed from those things but I'm familiar with the what and the why.
I mean, that is the point of the safety wiring right? So it doesn't vibrate the little bastards out?
Reactions: trenchfoot
trenchfoot
16,156
8,752
No prob, I assumed that's what you were referring to, just wanted to make sure.
Reactions: [DHT]Osiris
Zorba
15,613
11,256
Yeah, the nuts are supposed to be pinned. Not sure of the nut type, but distorted thread, self locking nuts are very common, giving you 2 locking methods.
woolfe9998
16,242
14,245
Without the minimum equipment lists (MEL), if a reading light on seat 36E burned out, the aircraft couldn't take off until it was replaced. The MEL allows them to fix the light within 10 days and go for now. Literally nothing on an airplane can be broken or not working without some sort of authorization, the MEL being the most common. The MEL is based on the safety design of the aircraft and takes redundancy into account. It also provides any additional inspections or operational restrictions required to operate with that item not working.
MELs can be abused, but the FAA and pilots come down hard on this. My old operator lost their ability to MEL the aux power units on some fleets because they were being used too often.
Sorry, I'll try to spell them out in the future.
Thanks for the explanation.
You only need to define an abbreviation once (in parens, for example) then you can continue to use it without clarification. "Minimum Equipment List" comes up straight away on Google, but not MEL.
Reactions: Drach
Nov 17, 2019
13,456
7,907
Idiot lights need to be prioritized. A seat or bathroom door light can be skipped for a short period.
A cabin pressure lights says (should say) the plane doesn't leave the ground.
Nov 17, 2019
13,456
7,907
I haven't seen this mentioned here yet:
Passenger phone found on ground after Alaska Airlines emergency
abcnews.go.com.ico
ABC|8 hours ago
NTSB investigators arrived in Portland, Oregon, on Saturday to begin their investigation into what happened on Alaska Flight 1282.
And they've found the door:
Emergency at 3 miles high: Alaska Airlines pilots, passengers kept calm after fuselage blowout
Passengers remained surprisingly calm after an Alaska Airlines flight had part of its fuselage blow out three miles above Oregon.
This photo released by the National Transportation Safety Board shows the door plug from Alaska Airlines Flight 1282 on Monday, Jan. 8, 2024, in Portland, Ore. A panel used to plug an area reserved for an exit door on the Boeing 737 Max 9 jetliner blew out Jan. 5, shortly after the flight took off from Portland, forcing the plane to return to Portland International Airport. (National Transportation Safety Board via AP)
Zorba
15,613
11,256
Article on the United Findings. This looks like the bolts that were loose were not the lockout bolts but the bolts that hold the fittings on to the door.
There are 2 automatic controllers and you can manually control. To dispatch the aircraft without one of the automatic controllers (which Alaska never did), the other automatic controller and the manual control must work correctly.
The investigation will determine if it was related or not, but good chance it wasn't related. Doors scream and howl loudly when they leak. I think a leak big enough to set an automatic pressurization lights would have been obvious to people on the aircraft.
Reactions: iRONic
skyking
22,889
6,054
The United discovery is good news for Alaska.
Someone had mentioned that possibly Alaska had messed up the door with their own inspection and acceptance process.
Now we can assume the fleet wide inspections are the right thing to do.
It also means that the emergency Airworthiness Directive ( AD) system is working as it is intended.
Something changed in the process with the MAX. They'll find it and there will be some FAA hand-slapping. They may have to slap their own hands for a lack of oversight.
Reactions: iRONic
ElFenix
102,408
8,596
Shoulda allowed higher quality union labor in that shop. Boeing got taken over by McDonnell Douglas* and Douglas's beancounter jack welch sycophants were put in charge and moved the corporate hq to chicago so that an engineer in seattle couldn't walk into the president's office to say, 'we need to change this or people are going to die.'
*boeing was run by a bunch of engineers who didn't realize that mcdonnell was buying boeing using boeing's money
ftfy
Nov 17, 2019
13,456
7,907
Some bits:
"Only seven seats on the flight were unoccupied, and as fate would have it, these included the two seats closest to the blown-out hole. "
"On Sunday, a passenger’s cellphone that had been sucked out of the plane was found. It was still operational, having survived its plunge from the sky.
It was open to the owner’s baggage claim receipt. "
Reactions: Pens1566
Paratus
17,770
16,127
*boeing was run by a bunch of engineers who didn't realize that mcdonnell was buying boeing using boeing's money”
Quote for MF truth.
iRONic
8,555
3,849
“Why aren't the black boxes made out of the same material an iPhone is???"
