Boeing problems...
Page 14 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
[DHT]Osiris
17,571
16,943
There has to be a first flight with people on board. Flying people is part of the certification process.
Weird, I always assumed 'test flights' were done with everything but the human, then they include the human after the tests are done.
Are those 'test plus human' still considered test?
sdifox
101,219
18,227
Err there is a reason test pilots exist.
[DHT]Osiris
17,571
16,943
Well, a test pilot for a flight system that requires a pilot makes sense. Orbital flight vehicles don't require a pilot necessarily, they've been remote capable for what, decades? I can't fathom why your first fully assembled test flight of a system would include a human that can't affect change if anything goes wrong.
Zorba
15,613
11,256
This isn't the first flight, it is the third flight and it is a test flight.
For the record, SpaceX also did a test flight with people and has also scrubbed launches of Crew Dragon.
BTW: This was an Atlas V problem, not a Boeing issue. Yet, Boeing still gets the shit for it. Why don't you complain about ULA/Lockheed Martin?
[DHT]Osiris
17,571
16,943
I wasn't aware they had multiple launches already, that's on me.
I'll complain about ULA/Lockheed when they demonstrate a cultural issue the way Boeing has. I shit on Boeing because Boeing decided to shit on engineers at some point in the last 20-30 years, and promote all the MBAs and marketing goons. ULA/Lockheed (and others) may have done the same, but it hasn't resulted in people dying.
Zorba
15,613
11,256
The O2 systems on Lockheed F-22 were giving pilots blood poisoning and making them pass out in flight resulting in at least one accident. The Lockheed F-16 is nicknamed "The Lawn Dart" because they crash so much.
This problem was an ULA problem, yet you blame Boeing instead of ULA. I'm guessing the Key Bridge failure was also Boeing's fault because Boeing paid them to ship some parts, just like Boeing is paying ULA to transport their capsule.
I'm not saying Boeing doesn't deserve some extra criticism right now, but right now it's just an emotional dog pile.
[DHT]Osiris
17,571
16,943
Probably true, but thems the breaks. I didn't put the blood in the water. Enough emotional pressure and the next MBAs that come along might remember to not fire half their engineers.
hal2kilo
26,660
12,731
I seem to remember footage of an early test flight of an F-16 that could barely get off the ground and once airborne was difficult to land. Modeling has gotten somewhat better now.
Zorba
15,613
11,256
I do agree with your premise they did make their bed with decades of laying off the experienced people and union busting. MBAs won't learn though.
Zorba
15,613
11,256
YF-22 crashed in the test competitions. Lockheed set the flight control against wrong at landing, leading to severe pilot induced oscillation.
[DHT]Osiris
17,571
16,943
See above, flight platform that requires a pilot vs one that doesn't. Humans are passengers on space launch vehicles, unless there's some new space planes I'm unfamiliar with.
Paratus
17,772
16,132
All of our capsule have manual flight capability for orbital ops. Manual handling characteristics is a part of the certification process.
[DHT]Osiris
17,571
16,943
Right, but it's not necessary. You could do a hundred test flights with an unmanned capsule prior to manning it, that's all I was saying. If they've done unmanned launches of these specific capsules then I stand corrected.
Zorba
15,613
11,256
They've already done 2 unmanned flights.
pmv
15,142
10,043
I do wonder if the travails of Boeing are, in essence, the long tail of neo-liberalism.
Given that much of the commentary seems to trace the problem back to the McDonnel-Douglas merger, and the switch from being an engineer-run business that happened to make money to being a money-making business that happens to do some engineering, I wonder if it's not just another example of the shift towards an obsession with share-holder returns that began in the Reagan/Thatcher era? It just took a long time to start having noticeable effects in the aerospace sector, because there's so much inertia in that sector.
I mean, a lot of the bad effects of Thatcherism/Reaganism seem to have taken a very long time to become apparent (our water companies going bust, the rise of both China and Trumpism...). Maybe the decline of Boeing is just another one of them?
sdifox
101,219
18,227
I see Boeing issues exactly like an engineering issue. How thin can you make the tincan before it fails. They just happen to be reducing the headcount of people that know how tincans work.
Zorba
15,613
11,256
I was thinking about this the other day. SpaceX takes investment money and uses it to do cool things. Boeing does cool things to give investors money. Obviously the sustainable spot is somewhere in the middle of those two extremes.
Reactions: iRONic
Zorba
15,613
11,256
Which apparently wasn't enough to tease out a faulty valve and a He leak.
I don't think Helium leaks are that uncommon, helium is a bitch to seal up. It's actually used for leak detection a lot because it's so small it can get through any leak path. But a tiny He leak is unlikely to hurt anything.
Not sure what the valve issue was, but also near zero chance the valve was directly designed by Boeing. Of course as the system integrator it's on them, but it likely was someone else's way too thin and inexperienced engineering staff.
pmv
15,142
10,043
As I understand it, the thing about Boeing is that it seems to have undergone a significant change of character, and every discussion I see of it traces it back to that merger. Its earlier record is actually slightly surprising to me, insofar as it really did seem to put pride in engineering quality far ahead of maximising profits. Hence its safety record was really very good.
Maybe it's just coincidental, and an accidental consequence of what just, by sheer chance, was the nature of its early management vs the corporate culture of McDonnel-Douglas, but also in that respect its previous nature seems very much a product of the post-war boom years, when such an attitude was possible, and the shift seems of-a-piece with the way _everything_ has gone downhill since the end of the boom.
Much of the rest of the corporate world seems to have abandoned that conscientious, pride-in-one's-work approach long ago, but it seems that because aircraft development is such a long-drawn out process (and aircraft purchases such a long-term investment), it's taken longer for that shift towards short-termism and profit maximisation and 'shareholder value' to have filtered through in the aeronautical sector.
Seems that in recent years Boeing has started behaving much more in the way I'd (cartoonishly?) imagined corporations to behave, whereas up till quite recently my expected image of them would have been unfair.
