Boeing problems...
[DHT]Osiris
17,574
16,948
How about rather than damage avoidance we go for mitigation? A pre-engine blade system who's only goal is to powderize or gooify anything organic that enters the engine prior to it reaching the sensitive bits.
Zorba
15,613
11,256
OK, after researching the topic a bit, I think I can make someone here very, very rich with a patent (share some of that money with me and don't be a scrooge, ok??).
So what we need is a high resolution camera that can detect the presence of a medium to large sized bird in front of the engine in a matter of milliseconds. Upon detection, a massive airbag is deployed that is too big to enter the engine. At the same time the engine will automatically shut off. When there is no suction left due to the completely shut down engine, the airbag will naturally fall down, at which point the pilot can restart the engine. The airbag on its way down, upon reaching a certain drop velocity can then deflate through the automatic activation of a self puncture mechanism.
Yes, this all sounds very expensive. But it could be cheaper than losing an engine and replacing it, or the entire aircraft, not to mention loss of life.
A jet engine can suck in a person and turn them into jelly in a fraction of a second at idle, don't think your airbag will survive. The amount of energy in a bird traveling at 200 mph is quite high, which is how it damages the engines.
Reactions: hal2kilo
Zorba
15,613
11,256
One that would very much screw up the aerodynamics going into the engine. Second, there is a lot energy in a medium or large size bird at 200 mph. The fan blades of a GE90-115B weigh about 35 pounds each, at take off power the centripetal force trying to pull them outward is over 80,000 pounds. This is what is being damaged by birds. Your bird grinder would have to be pretty stout.
19,220
In Star Wars, this problem would've been solved with a droid attached externally to the engine that would slice and dice any incoming objects with a lightsaber.
[DHT]Osiris
17,574
16,948
the engineering on those engines is fantastic. They eat hail and snow and copious amounts of tropical storm rain, without failure. to think that some keyboard warrior is going to patch it all up with his dimbulb idea is quite funny.
Hey now, I won't be satisfied until they can soak a henchman without damage. Until they can eat Crow, I guess you could say.
Reactions: skyking
Jan 14, 2015
56
123
Elon could design the best airplane engine grate, with AI. No doubt.
Some kind of conical screen or grate over the intake would probably have the best chance of working. Something that could deflect objects around the outside of the engine, while still allowing enough air flow through.
If Musk was involved, just think of all the potential for punny twitter jokes. ("The gratest thing to happen to aviation!" etc.)
brycejones
30,373
31,469
Yeah no one has every thought about bird strikes or FOD until you brainiancs started to.
iRONic
8,556
3,853
I knew that any words I typed in this thread would be useless and wasted. But I appreciate some of the laughs…
I'm sure someone somewhere could scare up the video of the 25 pound frozen turkeys they shoot through the intakes of these engines during tests if you're that interested.
Reactions: hal2kilo
Jan 14, 2015
56
123
come on you collective fucking morons!!
" gee I wonder why they did not do this"? blink blink......
perhaps because it won't work, they thought of it !75! years ago, right before you were born and nope.
Yeah, I've got to admit in retrospect that my post was pretty stupid and embarrassing. It should be common sense that if that idea was workable, it would have been incorporated into the standard designs decades ago. Not sure why I was so tone-deaf to that. :flushed:
Reactions: iRONic and feralkid
Fenixgoon
33,691
13,420
I mean they do blade-out containment testing by exploding a blade during engine operation
uclaLabrat
5,632
3,046
I mean this is a very well known problem that engine and aircraft manufacturers have attempted to mitigate for a long time now (all engines must be designed to withstand at least one bird strike). I strongly suspect if the answer were as simple as a grate it would have been done a long time ago.
My uncle worked for pratt and whitney his whole career and they used air cannons and store bought turkeys to launch into running engines to simulate bird strikes. One time someone forgot to thaw the turkey 🤣
35,623
The turkeys aren't frozen! :eek:
Reactions: iRONic
Indus
16,601
11,410
Can't rely on Boeing to get going anymore it seems..
Even before Wilmore and Williams blasted off June 5, their capsule sprang a leak in propulsion-related plumbing. Boeing and NASA judged the small helium leak to be stable and isolated, and proceeded with the test flight. But as Starliner approached the space station the next day, four more leaks erupted. Five thrusters also failed.
