Originally posted by: LolaWiz
Originally posted by: LadyBuggy
Originally posted by: SLCentral
Originally posted by: FeuerFrei
Originally posted by: Special K
Drysol is the most powerful stuff I have ever tried. Most of the OTC products didn't work too well, so I did some searching and came across this stuff. You put it on only at night before you go to bed. I can put this stuff on and will seriously not be sweating at all (at least under my arms anyway) two days later, even when I'm working out. It normally requires a prescription, but it is OTC in Canada and you can find it for sale on ebay.
Gimme some.
I need the hardcore stuff.
I generally use Axe but it doesn't provide much wetness protection.
I used to sweat a lot too, so I went to my doctor, and he prescribed DrySol. Burns a little at night when you apply it, but completely manageble, and it goes away after a few applications. I can forget to put deodorant on for three days straight after putting it on, and it still works. If I put deodorant on everyday after using it, I use it once a week and I never sweat.
Sounds a lot like Certain Dry. I love Certain Dry. And it's OTC.
just an fyi, for me, certain dri does not work nearly as well as drysol. I know you need a script for drysol, but it is really worth it.
Originally posted by: Strk
Old Spice: Red Zone
that only goes so far. you still need deodorant.Originally posted by: Sheepathon
Bathing well.
i think the OP was still talking about the underarm variety.Originally posted by: logic1485
Whoa, whoa people. This thread is about deodorants, not anti-perspirants
Deodarants are usually just spray like colognes, but they come out like an air freshner, and don't do jacksiht against sweating, they just attempt to cover up the smell. The only deodorant I've used is Axe, and they still suck.
Now, anti-perspirants on the other hand, I am using Old Spice High Endurance Invisible Solid Pure Sport. This is also a deodorant, so it also gives off a good smell (it says anti-perspirant/deodorant on the front)
Not all anti-perspirants are good smelling, and those are just anti-pesrpirants. The ones that are also good smellin, I'm assuming they are called anti-perspirant/deodorant.
Originally posted by: MisterJackson
Gillette clear with "power caps". Awesome stuff. Dries clear, doesn't stain, and the power caps actually last longer than the regular gilette clear without powercaps.
Originally posted by: BatmanNate
Old Spice burns like the fire of seven hells, yet I continue to use it.
