...and the petty thieves and crack heads who aren't smart enough to break in another way.Just buy a good lock. If the motherfuckers want in badly enough, they're going to get in. A lock isn't going to stop them.
Locks only keep out the honest people.
Full disclosure - I can tell you that I pick locks and your front door is not where I would enter. I would go into the back yard and enter the patio. Do you keep a rod in the patio door?
If you can find a lock that uses master and slave keys then your good because those are a bitch to pick because of the duel tumblers. Pick guns are somewhat successful on those.
Thread delivers.
LOL @ the sawzall and go through a wall people. It will NOT be 5 minutes to go through siding AND sheathing AND studs AND insulation AND drywall. It WILL be obvious what you're doing and that you're not there to fix anything.
Door getting "kicked in" is less ridiculous but still not a concern. Unless you are very strong, you won't be kicking in an exterior grade door. Interior doors are much lighter and their locks are far weaker, so they're a different story. French doors (glass doors with multiple lights) might fail, especially older ones.
The double cylinder deadbolt idea might be the worst of all. How does that help?
I had a friend who worked construction to pay for his expenses through college, he used to say the exact same thing. Don't go through the door on new houses those are solid, go through the walls! 😉I built houses for 10 years. It would be less than 5 minutes to get through the wall. More like 60 seconds. You severely overestimate the strength of 1/2 inch plywood and drywall, and you don't need to cut any studs unless you are so fat you can't fit through 16 in.
Its easy enough to put a hammer through plywood too.
His MO was lock picking. I think he looked at it like a challenge.
http://boingboing.net/2009/05/31/profile-of-the-lock-.htmlMedeco can't be bumped
