Originally posted by: npoe1
Originally posted by: waggy
red makes the car faster!
My blue motorcycle is faster than your red motorcycle.
And it leaves a pretty cue chalk like streak when ya dump it.
Originally posted by: foghorn67
Originally posted by: WhoBeDaPlaya
That's what I've been doing, since I have to pass through residential and school zones anyway. How cold is extreme cold though? 0F? -20F?Originally posted by: foghorn67
Simply start the car, and drive it gently until it warms up.
The expception for cold weather starts doesn't really have to do with the oil. I think it has something to do with the different types of metals expanding at different rates when warming up to abruptly. Causing valve malfunctions and engine seize.
For example my forged pistons have the familar 'piston slap' noise until warmed up.
Originally posted by: lupi
Can we get a faq on this thread. Half the people sound serious about what they're saying while the other half seem to be joking.
Sorry, this is NOT a myth. The gasoline you buy is almost never 'made' by the company you buy it from. After delivery from the pipeline, the brand is then distinguished by additives.Originally posted by: BoomerD
Gasoline is gasoline, regardless of where you buy it.
Wait, this is not true? Then splain to me why old folks in Florida have stuck blinkers? I am sure it is old blinker fluid.Originally posted by: shabby
Originally posted by: Zolty
Blinker fluid needs changing every 15k miles, or until it turns a green color.
Oh snap, mine needs changing!
Originally posted by: PingSpike
The whistle goes woo woo.
That's because your forged pistons expand more than cast pistons, and therefore require more piston to wall clearance. So they slap when cold, simply because there's more room for them to wobble.Originally posted by: foghorn67
Originally posted by: Zenmervolt
I was just going to say that if the vehicle is designed such that the knock sensor can accomodate premium with the allowed timing adjustment range then putting premium in really will improve performance.Originally posted by: MercenaryForHire
1. S2000Originally posted by: BoomerD
Running premium in my Honda really improves the performance...
2. CBR
- M4H
ZV
Originally posted by: Pacfanweb
With today's oils, there's really no reason to warm the car up at all. By the time your engine catches and you can physically let go of the key, the oil is everywhere that the pump pushes it to.Originally posted by: foghorn67
Myth: Warming up the car will ensure everything is well lubricated on startup.
Exception: EXTREME cold weather.
As you said, unless in extreme cold, you can start it and drive it like you stole it with no repercussions.
I've talked to a couple of Ford engineers that agreed with me on this when I was trying to get this argument settled.
Originally posted by: IGBT
..premium gas is special and necessary.
Much more intelligent than ASSuming the vehicle in question has anti-lock breaks. If you wanna make an ass out of yourself fine, dont inflict your ignorance and stupidity on me.Originally posted by: RGUN
WHAT?? So you're driving along an icy road and you need to slow down, apply brakes and use all the wheels and the ABS safety net OR downshift to a lower gear therefore making power application much less smooth and risk locking the wheels? yeah thats intelligent alright.Originally posted by: shortylickens
FTW!Originally posted by: junkiefp
Originally posted by: Pacemaker
Originally posted by: Vic
AWD/4WD helps you brake in slippery conditions.
I have never heard anyone say that, but it's really stupid. Just goes to show that people don't know what the acronyms mean.
Hate to explain it to idiots but it does when you downshift...
Downshifting and/or engine braking in slippery conditions is much better than using the brake pedal.
And better control means less of a need to brake in the first place.
But the original point still holds true: Vehicles have 4 wheel brakes regardless of drive.
As for the halogen/blue lights I wish more people would get a clue. Those things dont help you see shiate.
I helped a guy change his headlights one night. We went driving around town and he was like: "Dude, these things suck!"
They look really cool and annoy the crap out of the other drivers. Give them up.
Spend the money on something that will help you, like a garfield toy with suction cup hands.
As it so happens, my current vehicle is a little older and doesnt have ABS. But it has 4 wheel drive and 4 proper winter tires on it.
Incidentally, questioning someone elses intelligence does not enhance yours. It only makes it easier to point out how dumb you really are.
Now please go to bed and let the grown-ups finish their conversation.
Originally posted by: thetxstang
Here's a myth I learned of recently: I'd always heard that running your car on Max A/C was harder on your cooling system than running it in Normal A/C mode. An automotive A/C technician that I know and trust recently explained that this is not the case at all.
Evidently, when running your car in Normal A/C mode, outside air is allowed to blow over the evaporator core, which, since the outside air is usually much warmer, makes it harder for the evaporator core to cool and do its job. Conversely, when your A/C is set to Max, the air is set to recirculate mode, using the already cooled cabin air to blow over the evaporator core.
He also said the following method is the best way to cool the inside of your car on a hot summer day: Use the Normal A/C setting for the first couple of minutes or so, then set your system to Max A/C. Maximum cooling and the most efficiency, FTW!
If a sensor was placed behind the evaporator, a simple controller could modulate the outside air damper (using an electrohydraulic actuator or EHA rather than the conventional vacuum actuator to prevent excessive engine vacuum loading) to provide optimal evaporator return air temperature. 🙂
Originally posted by: her209
You get better gas mileage when using higher octane gasoline since you get more "ummph" for the same volume of gasoline.
Post some of the most persistant automotive repair myths that you've seen or heard, preferably things that can apply to any car and aren't model specific.
Some of my own favorites:
1) If the lights come on, the battery has to be good, so it's not worth testing it with a multi-meter.
2) Nitrogen in your tires will give you a smoother ride.
3) Blue tinted bulbs help you see better.
4) If you have keyless entry and you lock your keys in the car, you can call a friend on your cell and have them use the spare remote to unlock your car if they point the remote at their phone and if you put your cell phone near the car.
Other entries?
ZV
I remember hearing about that a month or so ago on the radio and i think the host actually got it to work. ill have to try it on my car.
