Originally posted by: mrSHEiK124
Dude, I love your car :heart:
Thanks.
Portable, no reliance on an air compressor that could fail at a critical time, non-flammable.Originally posted by: feralkid
What's the advantage of using nitrogen?
Originally posted by: Zenmervolt Absolutely no way it was the battery. The alternator, even at idle, puts out sufficient energy to run the engine even if the battery were removed from the car. Unless the alternator is defective as well.
Under no circumstances should a running automotive engine be dependant on the battery to remain running.
ZV
Doubt it. The car will run without the battery even connected.Originally posted by: ElFenix
ZV
while i agree with you in principle, the alternator tested fine once i got it over to auto zone or where ever. put a new battery in, and it's worked ever since. may have had something to do with the corroded terminals, dunno.
Probably like I posted earlier in the thread: The idle strategy of the ECU was affected by the battery going dead, and that's what caused the stalling problem.
It wouldn't restart simply because the battery was still dead....but it didn't stall because you still had a dead battery hooked up after the engine was running.
Did it all winter with my Mustang. It's pretty easy to match RPM to wheelspeed. You simply shift, bring up the revs before engaging the clutch, and slowly release it. Then, after changing gears, you let off the throttle. No wheelspin. Sure, if you dump the clutch into the lower gear you'll break traction, but you shouldn't be doing that.
Should NOT be done with an automatic, because that will just slam into gear without rev-matching, but on a manual you should be able to match RPM with wheelspeed for the selected gear.
If you invoke ABS, you've already screwed up. I've never had ABS kick in on anything but a panic stop, even in snow or on ice. ABS should not be modulating your braking, even in bad conditions.
ZV
If I gave you the keys to my Z in the snow, there is a 100% chance that you'll be sliding all over the place. There is no traction at all. None. Rev matching is useless because the wheels would still spin. There isn't a chance that the car is drivable in the snow with the tires I have on it.
My car wouldn't make it up my driveway, which isn't even hilly. It also wants to fall down the slope of the road, so you end up on the side of the street. As soon as you start moving, the tail end falls down the crown of the road. Put it this way- there is so little traction that 5th gear still spins from a dead stop with little to no gas required.
The fact that you were able to drive your Mustang all winter tells me that it's much more manageable than my car. Trust me, it's unbelievably bad.
Waaaaaait a minute, 91TTZ = 1991 Twin Turbo 300ZX?
Yeah, that's me.
Text
Originally posted by: BoomerD
Other than grades, ALL oil is the same
Hmm, I guess those 3-5 mpg increased gas mileage that I used to see from quality synthetics was a myth then. My Dad sells somewhat boutique industrial and maintenance products, including oil, and the results were noticeable and consistent. I can't vouch for the stuff on the store shelves, but his stuff works.
Originally posted by: nkgreen
This is sorta off topic, but does anyone know how to shift in a MT without using the clutch? I know it can be done and I would never try it, but I'm just curious.
The first part is right, but the second is mostly incorrect. Many cars actually tend to lift as they go faster. A rear spoiler will counter it and it will not cause the front wheels to have significantly less grip. If you were racing and had a skirted front, you get downforce there too. On a front drive, the rear tends to be light, so better distribution of weight via downforce in a highspeed will give it a better feel and undial some understeer.Originally posted by: IHateMyJob2004
1) That really stupid looking spoiler on your car does wonders for the performance of your front wheel drive vehicle. 99% of the time you are not racing the stupid thing, if you actually do race it. The end result is a lever based action that uses your rear wheel as the pivot thus reducing the amount of down force on your front tires. GENIOUS!!!!!!
Originally posted by: DivideBYZero
A muscle car can only be American.
Originally posted by: Kelemvor
Biggest myth of them all...
You should change your oil every 3000 miles. Of course the mechanics tell you that. You're paying them every time you have it done. Change the oil based on your manual, not on a mechanic.
Aother moron who can't read heard from I guess... the title for this thread, is "Auto repair myths"...and the topic has been things that are "common knowledge", but happen to be incorrect...MOST people have been able to figure that out...but, apparently, NOT everyone...
4) If you have keyless entry and you lock your keys in the car, you can call a friend on your cell and have them use the spare remote to unlock your car if they point the remote at their phone and if you put your cell phone near the car.
BWAHAHAHAHAHAHAA!!!!!
Originally posted by: jemcam
The # 1 myth is "If a car frame is damaged, it's totalled and will never be the same".
Edit: I use the word "frame" loosely since most people who perpetuate this myth don't know the difference between unibody and full frame vehicles.
Either one can be repaired and/or have sections replaced safely.
Ha, nitrogen in tires.
What a complete load of B.S. that is. Does absolutely nothing but inflate the tire.
Hmm, I guess that 3 hrs/night sleep for the past several nights paid off! :laugh:
Oh, and fvck you. 😀
Originally posted by: Vetterin
There is really nothing wrong with your left front wheel falling off..........."they ALL do that".
Originally posted by: RGUN
Its not going to help your CBR
acetone improves gas mileage
people won't notice that dent with the LeBra on
smoking while pumping gas is dangerous
leaving the engine running while pumping gas is dangerous
