Originally posted by: MercenaryForHire
Originally posted by: BoomerD
Running premium in my Honda really improves the performance...
1. S2000
2. CBR
- M4H
Its not going to help your CBR
1. S2000
2. CBR
- M4H
Originally posted by: Pacfanweb
Ha, nitrogen in tires.
What a complete load of B.S. that is. Does absolutely nothing but inflate the tire.
Originally posted by: junkiefp
Originally posted by: Pacemaker
Originally posted by: Vic
AWD/4WD helps you brake in slippery conditions.
I have never heard anyone say that, but it's really stupid. Just goes to show that people don't know what the acronyms mean.
Hate to explain it to idiots but it does when you downshift...
Originally posted by: shortylickens
FTW!Originally posted by: junkiefp
Downshifting and/or engine braking in slippery conditions is much better than using the brake pedal.
And better control means less of a need to brake in the first place.
But the original point still holds true: Vehicles have 4 wheel brakes regardless of drive.
As for the halogen/blue lights I wish more people would get a clue. Those things dont help you see shiate.
I helped a guy change his headlights one night. We went driving around town and he was like: "Dude, these things suck!"
They look really cool and annoy the crap out of the other drivers. Give them up.
Spend the money on something that will help you, like a garfield toy with suction cup hands.
Originally posted by: broon
Tailgate down gives you better gas mileage.
Tailgate down would reduce the drag obviously (unless you had a cap or something). Reduced drag = decreased power required --> less power required means less fuel consumption. See where Im going here?
Except you're wrong. 😉 Tailgate down doesn't decrease drag, it increases drag. I'm not a scientist so excuse my non-scientific language, but the air swirling around in the bed of the truck basically creates a "bubble" that the air going over the truck flows over.
Also so the water in the air won't freeze at 30+ thousand feet. I told some guys at a dealership who mentioned that they used nitrogen in airplane tires that next time I decided to drive my car at 30,000 feet, I'd be sure to stop by and fill up with nitrogen.Originally posted by: MS Dawn
Well when one considers the air we breath is almost three quarters nitrogen.
I believe the aeroplanes use it for the gear wheels - pure, dry nitrogen so in case there is a fire in the well and the tire blows up it doesn't provide an oxidizer. At cruising altitude most fires won't burn due to lack of sufficient oxygen.
I can attest to the fact that tailgate down doesn't help.....I have a full size Chevy drag truck. I tried it multiple times at the 1/4 mile track...tailgate up and down. Made absolutely no difference in ET or MPH. So it stands to reason that it wouldn't help mileage.Originally posted by: mugs
Don't you own a certain DeLorean equipped with a Mr. Fusion? 😉Originally posted by: Pacfanweb
So the 87 was easier to start, right? The premium should be harder to start in cold weather.Originally posted by: DarkKnight69
I ran 2 tanks of premium in my excel (1.5l, 93hp). No performance difference...However, there was a noticble difference in how easy it is to start in cold weather running 91 to 87...
WHAT?? So you're driving along an icy road and you need to slow down, apply brakes and use all the wheels and the ABS safety net OR downshift to a lower gear therefore making power application much less smooth and risk locking the wheels? yeah thats intelligent alright.
That's what I've been doing, since I have to pass through residential and school zones anyway. How cold is extreme cold though? 0F? -20F?Originally posted by: foghorn67
Simply start the car, and drive it gently until it warms up.
I stand correct, perhaps if you put a spoiler on the back of the cab (a la Subaru WRX) it would direct some air downward and develope Laminar flow out the back of the bed?
Originally posted by: Zenmervolt
You're both right.
At a constant speed, especially higher speeds, A/C is typically more efficient. When speed varries, A/C is less efficient. The A/C compressor carries a healthy amount of inertia and when a car is accelerating/decelerating often it is felt much more than when the car is at a constant speed.
To wetcat, remember that drag increases with the square of speed, double your speed and you quadruple your drag. All else being equal, you need 8 times the power to double your speed (4x power to overcome extra drag multiplied by 2x more power to double your speed). A slight increase in drag at 30 mph can have a huge impact at highway speeds.
ZV
Pretty sure that's some screwy math there...
You're both right.
ZV
That math sounds right to me.
The power needed to push an object through a fluid increases as the cube of the velocity.
You're both right.
ZV
Don't forget your muffler bearings!
You also have to figure another reason that A/C works better at highway speeds: Cooling. There is more air moving across the condenser, so the refrigerant is cooler and is therefore more efficient at removing heat from the passenger compartment air.
Plus, if you drive a long distance, a good A/C system will get the air regulated so well that it won't have to run anywhere near as much as it would sitting in traffic.
edit: which is essentially what ZV was saying.
4) If you have keyless entry and you lock your keys in the car, you can call a friend on your cell and have them use the spare remote to unlock your car if they point the remote at their phone and if you put your cell phone near the car.
WTF! 😕
Originally posted by: waggy
red makes the car faster!
