AtenRa
- Feb 2, 2009
- 14,003
- 3,362
- 136
They share the same socket on the desktop dont they?
And the PCIe lanes are on the CPU die and have nothing to do with the socket.
I guess he saw it here:
The rest may only have x8 btw.
Socket pinout limits maximum number of PCIe lanes.
It is beyond me why they're approaching things in this way. I do not think that they stand any chance at all. They should go for the budget/midrange market first with ZEN, gain some traction and then go for the high end. It is though to beat intel at high end this days, almost impossible. Intel is too far ahead. Take a look at AMD GPU high end versus nVidia. Had them gained anything by challenging nvidia like this? More so, that was a fair fight. On the CPU side, intel has all the advantages: the best manufacturing capability and an already proven top of the art uarch.First ZEN to be release will be for the High-End Desktop/Workstation and Servers. Those SKUs will compete against Intel Socket 2011-V3.
Later ZEN will also power the next AMD APUs that will compete against Intel Socket 1151 or whatever socket Intel will have at that time.
I think that they expose themselves too much and they assume too much risk. If they fail on the higher end with the new core, lower end products based on their new core will carry the burden of this failure. No one is going to desire them anymore. At least on the lower end / midrange they can compensate with features and value, but who is going to buy the lower end / midrange after they fail to deliver on the high end side.Why? Server/High end is where the big bucks are. Budget has been replaced by Cat chips, atom, and ARM. Midrange will use what ever they can get that trickles down from highend.
You don't make much sense: your're suggesting for someone to just give up. Blame? There is no such thing. Nobody is gonna blame them. They are struggling to deliver and this time I don't foresee a second chance.Those delays will be the last thing they do and better they declare bankrupt for good and Zen never needs to be released to.avoid the blame they will get.
Im not talking about that,
For example,
If you knew that Carizzo-L only have a single Memory controller would you say that Carizzo also have a single memory controller because they use the same socket ???![]()
OP hasn't been back since posting. I suspect some AMD astroturfing here.
Why everyone is compering the dual channel and not double the amount of cores vs Kabylake ???
Intels top end socket 1151 Kabylake will be a 4 Core 8 Threads with gen 9.0 iGPU.
ZEN will be up to 8 cores 16 threads no iGPU. Why and how does anyone believe it will compete against Kabylake is beyond me.
I dont expect it to even be in the same price category, ZEN should be more expensive than Socket 1151 Intel CPUs.
Of course. Some member was too "shy" of coming up and posted this news under some other account or it is pure propaganda from somewhere else. But I believe that most of the members discussing this can already tell that judging by the iq of their statements.Seems so.
No, but you know there's enough bumps there to support two DDR3 memory channels. If AMD is using a ~1000 pin PGA socket for AM4, there's just not physically enough pins for more than a dual channel controller.
I'll try not to be bitter in 2016 when I'm sitting on my expensive and fast 8-core / 16-thread Intel CPU while others aren't using any 8-core AMD chips because they'll be busy declaring bankruptcy.
3GHz 8C/16T Zen @ Haswell-level IPC would not be as attractive a solution to gamers as a 4.4GHz 4C/8T Kabylake @ Skylake-level IPC, IMO.
We'll see how a 95W 8C/16T AMD chip built on a Samsung low-power process clocks.
Do you know the specs of the FM4 socket ??? if yes then by all means post them here. Lets see if the socket can only support 16x PCIe Gen 3.0 lanes.
I dont believe any gamer would go for the 8C 16T SKUs, they will most probably opt for the 6C 12T that will be much much cheaper and better for Gaming.
Edit:
A 6C 12T haswell IPC ZEN at 4.0GHz will be more than enough for gaming.
