Originally posted by: mrSHEiK124
monoprice FTW
Originally posted by: rockyct
Well, at least this is better than headphone audiophiles paying $500 for a power cable for their amplifier. That's right a six foot cord between the outlet and the amp.
monoprice FTW
Originally posted by: SlickSnake
Monster Cable Z1 series speaker wire
This is what I use. The higher end Z series monster cables (Z2, Z3, Z4, ect.) use basically the same design, but the outer jackets become more expensive along with the connectors. I needed a heavy duty cable for long runs. And in a long run, the Z1 cable sounds noticeably better with greater clarity and definition than a standard cheapo 16 gauge speaker wire. You can hear improved bass and treble using these speaker cables. And for surround use you can hear improved dialoge and imaging. Most noticable is the fact it is a louder cable at the same volume levels on the reciever versus cheapo 16 gauge especially using 20 foot plus runs. It is also heavily shielded and insulated which is important if you have a lot of video and audio cables running side by side out of the reciever.
There are vastly more expensive cables made than Monster Cable. I can't quite figure out what all the Monster hate is about, other than the fact some pricey retail outlets choose to sell the cables at the suggested retail price. That does not mean you can't get Monster for a LOT less elsewhere. Why not rag more on the shady retail sellers for not lowering the retail price of the cables in the first place? I never paid retail for a single Monster Cable I ever bought. Usually I pay 1/4 to 1/3 of the retail cost just buying it on Ebay or some volume internet discounter out there. I bought a 250 foot spool of Z1 for long runs for about 50 cents a foot, brand new! That's $2 less per foot than the retail price. And at that price point, there simply is not a better speaker cable made of that quality for that price. Even the short Z1 runs I bought for the speaker mains never exceeded $1 a foot, including the gold plated connectors.
I also use these for both of my subwoofers on my 2 HT systems: Zbass100 Audiophile Powered Subwoofer Interconnect I did have a bit of trouble finding these cheap, since they were hard to find in the first place, and ended up paying about half retail price at $50 each for 12 foot runs. I had cheaper sub cables hooked up before, and the change of sub cables were not only noticable, I had to completely recalibrate my subs for them! But don't take my word for it. The simple fact is you can't possibly know what you are talking about when you trash their overall cable quality and retail price, unless you try it and hear it for yourself.
Additionally, concerning the Monster Power Bars they also work, as advertised. Even the low end Monster stuff like this can clean up most of the noise you would otherwise hear running from your AC power. I used to have a lot of line noise which was virtually eliminated using just the stage 2 power bars. Of course, you can pay $1500 retail and get the stage 5 stuff, too. Or just shop around a bit and find it for 1/3 off, or more.
For the quality you are buying with the lifetime warranty on cables and $250,000 equipment insurance on the power equipment with a 5 year warranty, you can only go wrong by buying some other cheap brand that might not be around to honor their warranty when the lightning surge takes out your entire HT.
So anyone spouting off here about how you don't get what you pay for with a Monster Cable has obviously not had a high quality cable in the first place to compare it to. And they also most likely can't figure out shopping on the internet well enough to not pay retail for it, when they need to buy it. I am sure for most people the cheapest Monoprice quality level works just fine. Just keep in mind not everyone is trying to hook up the cheapest made consumer products with the cheapest Monoprice cables. On something electronic of high quality at the higher end of the price range, you very well might notice various problems with the cheapest cables you can buy. And even Monoprice has cables for the same applications at different price points. Why do you think that is, hmmm? But if you do buy cheap, and it works fine for you, that's just great, too. Just don't be dense enough to actually pretend you always get what you pay for when you pay cents instead of dollars for every product you buy. It obviously just don't work that way. Even at Monoprice.
Originally posted by: gorcorps
"Studies" like this make me sad... and the people who call themselves 'audiophiles' and eat this shit up makes me even sadder. Before I go ranting here, I just want to say while I don't consider myself an audiophile I am more picky than most. But I AM a metallurgical engineer and have quite a bit of experience when it comes to metals, alloys, and how they're made and used.
First, while it may be a surprise to some of you that a coat hanger could produce that good of sound, it really shouldn't. A conductive metal will conduct, that's all there is to it. Gold conducts a bit better than copper which conducts better than lots of other metals but the fact of the matter is that many cheap metals will conduct well enough for speaker wire for most to not tell the difference. But that doesn't mean there's no reason to go with the cheap metals every time... you pretty much get what you pay for here. As mentioned before Gold is highly corrosion resistant. Add that with great conductance and you have a perfect metal to use for such applications. Copper and Gold are both also of the "face centered cubic" crystal structure which is known to be of higher ductility than other metals. This means they can be bent, twisted, and formed more easily without worrying about breaking them. Try to bend a coat hanger at the same spot a few times and it'll snap long before copper or gold wire of the same gauge. So with gold and copper you have a material that conducts electricity well, and can be warped without much worry. Can you really ask for a better material for a cable?
So where does your money for monster cables go? Into shielding which is quite important, warranties which many other companies don't offer, and durability. I use monster cables for my guitar setup because I can step all over them, run over them with chairs, etc without having to worry they'll short out. And if they do? It gets sent to monster for a replacement.
BWAHAHAHAHAHHAA!
Did you use those cables to hook up your bose system?
Corbett said:
BWAHAHAHAHAHHAA!
Hardly. You obviously know as little about Bose, as HT and cables in general. Bose HT in the box, has its own cables. And they are proprietary to the HT system. 😛
Corbett said:
BWAHAHAHAHAHHAA!
It was a joke. You are just too concerned with selling your snake oil to see that I guess.
Originally posted by: yllus
Engadget: Audiophiles can't tell the difference between Monster Cable and coat hangers
It looks like a group of 12 self-professed "audiophiles" recently couldn't tell the difference between Monster 1000 speaker cables and plain old coat hangers. Yeah, coat hangers.
The group was A-Bing different cables, and unbeknownst to them, the engineer running the test swapped out a set of cables for coat hangers with soldered-on speaker connections. Not a single one was then able to tell the difference between the Monster Cable and the hangers, and all agreed that the hangers sounded excellent.
I know that the defenders of Monster Cable are going to jump all over the source here, but it certainly rings true to my own experiences. During my term in retail I was up close and centre with Monster products and was hard pressed to ever find a difference in quality between their stuff and generic cabling. The power bars were the funniest bit.
Originally posted by: Agentbolt
You are really weird.
Originally posted by: Rubycon
What I find really funny about all this speaker wire stuff is people spend all this money to ensure the best connection between their box and receiver yet never peep inside either component to see how its wired! :laugh:
The pros use SJO cable - like your garden variety extension cord. Most is SJ (300V rated) but in high power installs we like to use 600V rated stuff. (SJO) Virtually indestructible as are the Speakon connectors on each end. Twist and click - goes nowhere even if someone trips on the wire - box keeps on ticking and the unfortunate individual does a face plant on the stage. :Q
Originally posted by: Safeway
Monster cables can cost as much as the television they are connected to. The only thing in this category I would ever buy would be an advanced surge protector/energy scrubber. Separate grounds for audio equipment drastically decreases fuzziness and buzz.
Audiophiles always say meaningless crap like that. Those statements are idiotic. If you hear a difference between lamp cord and monster cable, then you diddn't hook them up correctly. And where does that cable say it's shielded?
The only good thing about Monster Cables is that you can abuse the crap out of them, break them, then get a replacement. Thats it.
