Attention Mid-Range System Builders - Updated 08/01/2015
Page 28 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
tg2708
687
20
I'm not sure what a male in rebate is, sounds kinky though. A USB 3.0 HAF 922 at $60 after mail in rebate is not bad if you like the styling.
You seem unsure about it if i'm not mistaken. Do you have any recommendations on a case or you just choose a cheap one?
lehtv
11,897
74
As for the mobo+PSU, that's absolutely a viable option, but the two changes definitely need to go together. 650W is not enough to comfortably run 7970 CFX. I didn't consider a Crossfire-capable build because I don't expect many people to "upgrade to CFX", especially not when talking about a high-end card that is going to be in limited supply.
That's true enough and I don't criticize your choices at all if we're talking about a $950 AR rig.
I'd point out that even though 650W may be a bit borderline for 7970 crossfire, the mobo+PSU will both last across at least one GPU upgrade. That upgrade doesn't have to be another 7970, it could be two lower TDP next gen GPUs
dragonlord72
32
What is TDP in this context?
lehtv
11,897
74
Thermal Design Power or "board power". Basically the maximum wattage the card is supposed to be able to draw. Actual power consumption is usually quite a bit less at stock. Overclocking can reach, in some cases even exceed the TDP. It's indicative of the power requirement differences between different GPUs.
E.g. 7970 TDP = 250W, actual power consumption about 190-200W, can reach 250W with OC'ing. Meanwhile, 7870 TDP = 170W, actual power consumption about 130-140W, can reach 170W with OC. A next gen card in the same performance bracket as 7970 should consume about as much power as a 7870.
mfenn
22,400
www.mfenn.com
No worries, always good to have somebody checking behind me.
I just think it's ugly. I would personally go for a Corsair 200R or 300R.
mfenn
22,400
www.mfenn.com
New build posted, most of the combos expired, so that's a big shakeup. Also got in on that awesome Seasonic 750W deal even though 750W is way overkill for this machine.
mfenn
22,400
www.mfenn.com
New update, a MicroATX board makes its first appearance! It'll be a little small in the 300R, but this build doesn't need a full ATX board anyway.
Torn Mind
12,078
2,772
The CPU+Mobo combo link still links to the ASUS A87-A instead of the Gigabyte GA-Z87M-D3H.
mfenn
22,400
www.mfenn.com
New build, swapped out the case and PSU, as well as the RAM. I also posted some suggestions for upgrades to send the machine up to $1000. Of course, adding the HSF and overclocking from the start would also do it. I don't think that a GPU upgrade makes sense because the next logical step is a GTX 770, but IMHO it doesn't offer $100 more value.
dpodblood
4,020
The quality of Rosewill PSU's must have improved. I have never seen them recommended here before.
lehtv
11,897
74
I've seen them recommended ever since Capstone was released around 2 years (?) ago
mfenn
22,400
www.mfenn.com
Not all Rosewill PSUs are great, not by any stretch of the imagination. However, the Hive (Sirtec) and Capstone (Super Flower) series are make by respectable OEMs and are often on sale for good prices.
Techhog
2,834
With the mass 7950 price hikes, this thread needs an update.
Edit: Nevermind. I don't even know
lehtv
11,897
74
The motherboard combo link says "Sorry, the combo deal is no longer available.". Tried to find it via the combo search, seems like it's gone for real.
4670K + MSI Z87-G43 Gaming $360
4670K + MSI Z87-G45 Gaming $370
The MSI boards actually have better sound and LAN than Gigabyte z87x-ud4h. G43 has 6 phases and no SLI, G45 has 8 phases and SLI for $10 more, UD4H has 12 phases and SLI.
Also... Kingston V300 120GB is just $80, I don't think a TLC based Samsung is 25% better than an MLC based Sandforce. Nice build as usual tho :thumbsup:
mfenn
22,400
www.mfenn.com
:thumbsup: Thanks for the mobo suggestions. It was on a 72 hour combo deal, problem was I didn't know when the 72 hours started. :awe:
praeter
12
If you do not plan on overclocking do you recommend alternate chip/board combos?
Thanks for keeping this thread up!
lehtv
11,897
74
i5-4670K + Asrock Z87 Performance $320 -$20 gift card code (comes with 4670K)
Although there is no combo with this board for a non-K i54xxx, I think this combo is excellent if you're not planning to overclock. That's mainly because this board is the cheapest one with Realtek ALC1150 sound and Intel LAN.
monkeydelmagico
3,961
145
lehtv
11,897
74
Asrock is advertising the non-Z overclock feature which is a pretty nice feature but Intel doesn't like it. In July, Intel announced they will make chipsets other than Z87 completely locked with some microcode update. I haven't heard of it since, and I don't know exactly how they will deploy the update, but it sounds like overclocking will only be possible on Z87
monkeydelmagico
3,961
145
Bummer. That would make a fatality board a big fat fail. Guess that's why they are bundling and selling off inventory.
What if you just don't update BIOS?
