LOL_Wut_Axel
- Mar 26, 2011
- 4,310
- 8
- 81
Hmm. So I am on microcenter and have the Z77 Pro3 1155 ATX Intel Motherboard added to the cart. On the page it shows up 94.99 but when i go to check out it is showing up as $44.99. Is this the same one as the cpu+mobo combo you posted?
http://www.microcenter.com/product/387627/Z77_Pro3_1155_ATX_Intel_Motherboard
EDIT: nevermind, found out that it is a known deal lol.
Anyways, would one suggest I go with that mobo or an Extreme4. I honestly don't know the difference and I will be using this computer for gaming and video editing if that makes any difference. thanks
The Extreme4. See my previous post:
Of course, the Extreme4 would be $84.99, meaning $40 over the Pro3, but you're still saving $50 on the motherboard and $40 on the CPU in comparison to buying on Newegg. Since you're saving $90 total I say go ahead and buy the Extreme4 and the 3570K.Given the target of this build is to hit ~$1000 I'd recommend getting an ASRock Z77 Extreme4 instead. Sure, it's $20 more, but for that you're getting a ton more features:
-Better for overclocking: you get an 8+4 power phase design instead of 4+1.
-CrossFire/SLI: You do not get this with the Pro3 as it only has one PCIe 3.0 x16 slot and a PCIe 2.0 x4 slot.
-All the switches: useful for diagnosing your system. The Extreme4 has a Debug LED, a power switch LED, a reset switch LED, and a CLR CMOS LED. The Pro3 has none.
-More SATA ports: Four SATA 3 and four SATA 2, all right-angled. In comparison, the Pro3 has two SATA 3 and four SATA 2, all straight-angled. Straight-angled ports can mean problems with expansion cards as they can block them.
Twice the back panel USB 3.0: four instead of two. Pretty much all external hard drives nowadays are USB 3.0 compatible, and it makes a big difference in speed when copying large files.
For $20 more the Extreme4 is easily a better choice.
