Very quick and easy to setup. The CPU came on backorder, so it arrived the day after the rest of the parts.
The CPU Fan is HUGE with a 120mm fan! I am much more a fan of this than the AMD heatpipe sink. It came with a RPM rheostat, but I plugged in directly to the board, as the 120mm fan is not that loud. Speaking of size - If you have a super tall DDR module in the 4th slot, you'll have issues. Otherwise, you'll just have a tight squeeze adding / removing normal ones. I had 4 banks filled, but it cycled down to 333mhz, so now im at 2 banks of 512 ddr400.
The system runs nice, and I put a 7900GS in it. Audio sounds decent, and has the standard auto sensing jacks, and has an intel gigabit ethernet onboard.
The case is sleek, solid, and well laid out. Overall, I am very happy with this purchase.
