Arachnotronic
EDIT: Nevermind.
Yet some people are still cheering because the fastest 35W model is now slower than a 1-year old 15W Haswell-ULT chip (replaced months ago - Core i7 4600U is clocked 300MHz higher) by a smaller margin CPU-wise than Richland was. Also why comparable 37W Haswell dual-core & quad-core parts were not included in this comparison? A $225 standard voltage chip like Core i5 4310M should be way faster than the Core i7 4500U. While the iGPU performance is impressive (finally GCN @ mobile APUs) I wonder how much their advantage would be reduced had they used their fastest 17W part (running 256 GCN cores @ 424MHz) instead of top dog 512 cores @ 686MHz. That's 15W Haswell-U's real competitor, not the fastest 35W SKU.
@AtenRa - u do understand that they are comparing a 35W CPU vs a 15W one right. that mean less weight, thinner chassis and possible better battery life
and that GPU is not even HD5000 let alone Iris
But the FX-7500 19W part isn't clocked much lower the FX-7600P 35 W APU. So at least the CPU performance of the 7500 ought to be close to the 7600P, but with much lower power consumption. See:
Hey wait a minute, I thought it was all about design wins for you? You better run and tell HP that AMD's cost structure is far worse, I guess they never consulted you first! You notice they are releasing AMD EliteBooks ahead of intel's?
Side by side, AMD's Kaveri is far more appealing than whatever intel has. Kaveri is just getting rolling, and as HSA compatible software continues to roll out, AMD's mobile products make intel's look dated and much less advanced. Sure they compete on standard work loads, but fall far far behind in 3D, gaming, and when current and next gen software is utilized. Shills. They're so humorous. 🙄
I look forward to seeing how well Kaveri does in the market.
I look forward to buying and using Kaveri regardless of how it does in the market. That's the difference between investors and consumers I guess.
It's an awesome product with a forward looking architecture.
performance looks good, not really 750M level for the IGP but clearly much faster than ulv HD 4400, but it would be interesting to know the power usage compared to the ULV i5/i7 + discrete graphics, and also performance compared to "M" 35W i5s
memory bandwidth?
That doesn't necessarily mean that. It largely depends on the model itself. I just looked at Dell's 17R. It's 6.02 lbs with a Core i3-4010U. The Lenovo 17 inch everyday laptop is 6.4 lbs with a Core i3-4000MQ Processor. Even more striking, the Razor 14 inch is just 0.7 inches think and weighs only 4.47 lbs, yet it has a Core i7 4702HQ and GTX 870M.@AtenRa - u do understand that they are comparing a 35W CPU vs a 15W one right. that mean less weight, thinner chassis and possible better battery life
Besides the screen, I don't see what's really that bad. If you're buying more expensive models, you're paying for a chassis you're not going to be able to reuse and they'll rip you off if they were offering SSD's or more memory. Edit: Even with the screen, in the past, it was clearly fine to have only 768p if you were using it for gaming otherwise games would have played like crap.the Kaveri APU is still cutting corners compared to Intel offerings and so it is getting used in notebooks that are cutting corners.
I'm just happy to see AMD still creating competition and keeping a bit of a fire under Intel's arse in the mobile segment! Go AMD! Go!
Why? If you want AMD mobile, you're probably looking into playing games. If you want an Intel system that can play games, you have little choice in the same price range. There are countless Intel systems with crappy integrated graphics all the way up to i7 systems. Lenovo seems to offer the most for Intel's standard voltage chips otherwise you're looking at paying much more than a Kaveri system. Many of the OEMs have gone with ULV's even for 17 inch laptops (Ironically Lenovo has standard chips but no 17+ inch), and the OEMs want to segment gaming performance into premium laptop models.
If that is poor performance then what makes the Core i5 4200U???🙄
AMD playable, Intel not playable
There is a pattern emerging, no wonder Intel are trying their best to improve the iGPU performance more than the CPU all that time.
Im sure we will have power and battery life measurements of actual retail products when they will be available.
This positioning puts AMD into a bit of a niche,
IMHO, The USP of a kaveri APU (on mobile) is useful for:
-people want to play games on a laptop, graphically demanding enough for it to justify over intel's offerings, yet do not the desire the benefits so much to justify the extra costs of a (modest) dgpu, bc of the TDP constraints (35W) of the better gaming chips, these people also need to be comfortable with larger form factor laptops.
Actually the desire for more graphics power in a reasonable power envelope has been the main reason for my notebook upgrades since the introduction of mobile Intel's mobile Core 2. Not even gaming driven, just regular media and internet demands.
The business models are aiming for $799(HDD+16:9 WXGA) to $1299(SSD+FHD).I really hope the laptops with the FX-7600P aren't too expensive.
AMD better hope not. No way I would pay over 600.00 for Kaveri. At 500 dollars it is a deal, 600 maybe, but not more than that.
