Are you sure ???
Lets eliminate the CPU and see what happens with graphics only. From AT Kaveri review.
Core i7 4770R is 65W TDP.
Even a low 45W Kaveri iGPU is faster than Iris Pro in Bioshock. 65W Kaveri is 17% faster.
In Tomb Raider Iris Pro is ~10% Faster than 65W Kaveri.
Well, even vanilla Intel HD graphics are faster than Iris Pro. It seams that eDRAM is not always the best solution or the Intel driver is even worst than we believe.
Equal to 65W Kaveri.
So, where did you see that Iris Pro creams Kaveri at the same power consumption ?? And this is 22nm FinFet vs 28nm. Intel is way behind in graphics performance.
Also to note here that Kaveri 45W is equal or faster than the 100W Richland parts. AMD should of bring a GDDR-5 SKU even if the price was at $300+, it would completely eliminate the competition.
It's far from clear if the EU's in this product will be Gen 7 or Gen 8.
I suspect they may be Gen 7, so it isn't as exciting as it could be.
Sounds cool but then as long as the iGPU is only used as a GPU and basically dead silicon with a dGPU, it's not that interesting. I would rather prefer hexa- or octo cores in mainstream with weaker or no iGPU at all.
Francois Piednoel refused to confirm this on Twitter when asked if Gen 7 or Gen 8.It is clear. Broadwell comes with a Gen8 GPU.
Never heard that one before - have a source for such? After all, there's no question that texture sampling is a weak point of Intel's graphics thus far.
Are you sure ???
They can do that, but it would be unnecessary work, since Broadwell uses Gen 8 arch.Francois Piednoel refused to confirm this on Twitter when asked if Gen 7 or Gen 8.
The graphs you show, Seriously???.
Broadwell GT3e is the one with 48 EUs and eDRAM correct ?? If that is Iris Pro then what about GT4 ?? Is GT4 BGA only (Apple and OEMs ??)
If the unlock SKU has the 48 EU iGPU part + eDRAM and the retail price is maximum of $300, then it should be worthy of recommendation for High-End SFF builds.
Shoot in the dark here, but GT4 might has been a failed attempt by Intel to win console APU.
Why? At those settings its not playable at all.
@ Aten Ra
At more playable settings, they trade blows. The graphs you show, Seriously???.
Actually I can provide evidence:
http://www.anandtech.com/show/5871/intel-core-i5-3470-review-hd-2500-graphics-tested/4
3DMark Vantage Texture Fill:
2 samplers HD 4000: 6.1 @ 1.15GHz - 5.3 points/GHz
1 sampler HD 3000: 4.56 @ 1.35GHz - 3.38 points/GHz
1 sampler HD 2500: 2.93 @ 1.1GHz - 2.66 points/GHz
Page 12: Bay Trail presentation.
@ 700MHz it claims 1050 MPixel/sec. Now that doesn't make sense, unless it runs at asynchronous frequency. Assuming 2 TMUs, it would run at 75% frequency, and above with Anand's bench we get 78%, which is pretty close.
We are not evaluating APUs here as a product but only the iGPU performance. Playable frame rates is not what we are seeking for.
Eliminating the CPU influence (lower resolutions and image quality settings) really show the iGPU performance of each architecture. And those AT graphs clearly demonstrate that GPU wise, Haswell IrisPro is not that much more power efficient than Kaveri.
