Originally posted by: VirtualLarry
Originally posted by: Zebo
DFI or die. 🙂
They use aluminum electrolitics on their high power caps.. Same expensive ones you see on video cards and server boards..
I don't get it. Al electrolytics are the cheaper ones. (Well, not as cheap as the chinese-made ones, but they aren't the "expensive" ones.) Did you mean
tantalum caps? The really high-quality mfgs used to use those on their boards, even Intel's OEM mobo production for the big-name OEMs tended to use them. There is a bit of a socio-political issue with using tantalum caps these days though - the world's biggest supply of tantalum comes from the Congo Republic, and I guess the mining operations are both destroying the landscape, and fueling the political forces bent on usurping control of the gov't over there. Good technically, bad politically.
