Thats from the Pro-Clockers review... the way I read that both an agp and a pci-e 4x card will work at the same time.. for the 4 monitor support.. but that just can't be truePCI Express / AGP selection flexibility is also one of the features that can?t be missed out in this Dual series product line. Being the Dual Series, 4CoreDual-VSTA is able to support AGP8X and PCI Express Graphics card simultaneously, supporting up to 4 monitors together at the same time.
Originally posted by: ComatoseDelirium
Thats from the Pro-Clockers review... the way I read that both an agp and a pci-e 4x card will work at the same time.. for the 4 monitor support.. but that just can't be truePCI Express / AGP selection flexibility is also one of the features that can?t be missed out in this Dual series product line. Being the Dual Series, 4CoreDual-VSTA is able to support AGP8X and PCI Express Graphics card simultaneously, supporting up to 4 monitors together at the same time.![]()
Originally posted by: timzak
Just got one of these with an E4300. Worked right away at 2.4 Ghz stock voltage. Using Crucial Ballistix DDR400 and 6800GS AGP video.
My only problem so far is I can't get DOS to load up. My DOS bootdisk starts to load, then pauses with a blinking cursor for a LONG time before the a: prompt appears. Then it won't let me change drive letters to c:. I use Drive Image for backups and it runs through DOS, so this is kind of a big deal. Does anyone have any tips? I checks for any obvious bios settings and didn't see any that might be related to this.
Thanks.
Originally posted by: Javvis
Per request ...the following are the Voltages on the Asrock 775 VSTA Board:
agp "high" 1.59v
agp "low" 1.54v
DDR "high" 2.73v
DDR "norm"2.63v
DDR "low 2.53v
DDR2 "high" 2.0v
DDR2 "norm" 1.9v
DDR2 "low" 1.8v
Now back to my previous post question: I've purchased several of these Asrock 775 VSTA boards & recently built a system as listed below:
1.) 3.0 ghz Cedar Mill.
2.) 2 sticks 256mb Geil 3500 DDR memory sticks .
3.) AGP Card.
I set the FSB to 233 & the memory to 200 ...& it booted up at 3500 mhz without any increase in processor (30 C) temp.
I noticed while using the newest version of Everest ...that my Memory was running at 217 mhz & the memory/FSB divider was 6/8. I've always thought that it's better to run 1:1 or possibly 1:2. (Flexibility option is turned off)
Could someone please explain this memory/FSB divider thing for this board in detail using my setup with DDR & also if I switched to DDR2. I would like to run at 1:1 ...how would I do this ? I've looked elsewhere & could only find minimal info regarding this.
I've got a new 6300 CD2 ...but, I think the 4300 or upcoming 4400 would work better on this board because these CPU's have lower FSB (200 vs. 266) & higher multiplier.
I have come across this explanation by Slipstreem in regards to ram dividers. I'm sure I have posted it here in this forum somewhere before, hope this helps.
Quote
Hi peeps!
I've noticed that quite a few people who are relatively new to overclocking seem to be having trouble setting their DDR memory up correctly on this motherboard.
The following may be helpful to someone...
You cannot lock the memory speed on this motherboard, but you can manually change the divider to bring the memory speed back down when you overclock.
The dividers aren't expressed as dividers in the BIOS. They are expressed as DDR speeds which can be a little confusing.
I'll try to explain:
At 200MHz FSB (quad-pumped 800MHz for an E4300), the motherboard will give the following memory speeds for its stated 'DDR' speeds when used with DDR memory...
'DDR400' = 1:1 = 200MHz = DDR400,
'DDR333' = 6:5 = 166.7MHz = DDR333,
'DDR266' = 3:2 = 133.3MHz = DDR266.
These dividers hold true until the we reach an FSB of 240MHz where a new set of dividers are invoked as shown below. Now, suppose that we take the FSB straight up to the level that most unmodified Dual-VSTA motherboards will reach. This seems to be around 290MHz. The dividers and memory speeds will then be as follows...
'DDR400' = 4:3 = 217.5MHz = DDR435,
'DDR333' = 8:5 = 181.25MHz = DDR362.5,
'DDR266' = 2:1 = 145MHz = DDR290.
These new dividers make perfect sense when you consider that at an FSB of 266MHz, the memory speeds are actually DDR400, DDR333 and DDR266 again. This gives the correct memory speeds for processors running at a quad-pumped speed of 1066MHz, ie, the E6300, etc.
So, we don't have precise control over the memory speed achieved for a given FSB, but we can predict what it will be and select the appropriate 'DDR' setting in the BIOS for a given FSB.
Good DDR memory with slackened timings should manage at 290MHz FSB on the new dividers. If it doesn't, then knock the setting in the BIOS down to the 'DDR' setting below the one that matches your memory's actual DDR speed and try tighter timings to compensate for the underclock.
I hope this makes sense.
Cheers, Slipstreem.
Originally posted by: tno
Tim,
You may want to check the ASRock 775Dual-VSTAASRock 775Dual-VSTA thread for more information about tweaking this board. The boards are close siblings who, as earlier postings have attested, are separated by just a sticker (same chipset, different names).
There are over 2000 posts in the tread so I'd consider searching through them for DOS problems. As far as memory problems, I'm quoting the below with lots of info on overclocking and memory timings.
Tno
agp "high" 1.59v
agp "low" 1.54v
DDR "high" 2.73v
DDR "norm"2.63v
DDR "low 2.53v
DDR2 "high" 2.0v
DDR2 "norm" 1.9v
DDR2 "low" 1.8v
3.) AGP Card.
Quote
Hi peeps!
Cheers, Slipstreem.
Originally posted by: Mr Vain
What program are you using to find your memory speed?
Try HWINFO32 some programs like CPU-z don't read the chipset properly.
http://www.hwinfo.com/
Originally posted by: nyker96
Anyone who played with this board, does it overclock better than the original 775dual? Any data on this one?
I am getting slightly better overclocks, gone from around 300 to 315 stable.
Gary are we likely to see a review on this motherboard here at Anandtech soon?
Yes, and it will be with a Quad Core.
Originally posted by: Fercyful
Hi There!!
I just rebuild my system.
Here 4CoreDual-VSTA + Core 2 Duo E6600 (please check my previous system below)
I keep of course the EVGA 7800GS AGP, RAM and hard drives...
I have a doubt that I hope to can explain well with my humble english...
My RAM is 1gb DDR1 (400) + 512MB DDR1 (333) both running in single channel at "333"
(for luck they actually works!!)
In BIOS if I set CPU "AUTO" then in Windows XP reports that my CPU is running at 2.3 (instead of the 2.4) In EVEREST I check and says this: 9x256 = 2356 Mhz can be that when I set "AUTO" the CPU actually "syncs" with my low end 333 RAM and that is the reason of the bad speed report under windows... also notice that Everest says about RAM DRAM:FSB ratio 5:8 and runs at 160 Mhz!!! (not the 166 Mhz (333) I check at setup option.
BUT if I put in BIOS "CPU, PCIE Async" (not doing overclock, just changing that setting) then in Windows all works well and I see finally 2.4 there! (9x266 Everest) and the RAM fixes also: under Everest 166 Mhz (333 DDR1) All normal!
At the BIOS always the CPU is detected well at 2400 MHZ (E6660) my CPU is ok and all was boxed... and the RAM also is detected well at 333...
please any help with this? Maybe the system need at least a DDR 400 to have the FSB in a right way but I can test that right now...
thanks a lot for any advice!
