ASRock 4CoreDual-VSTA
Tedtalker1
398
Originally posted by: lookin4dlz
The USA is becoming a second-rate country due to the lackadaisical attitude people have towards education & so products are offered elsewhere first.
Please, No BS in this thread.
ANANDTECH MODERATOR
mhartsel
11
I emailed ASROCK and they promptly replied telling me that this motherboard would be available in the United States around March 1st....not sure why they are waiting so long to get the board over here. I too would be interested to see if they are actually shipping the current boards with the Ultra chip already installed....anybody pulled the heatsink or ran MBM, etc...to see what is under the hood ?????
The above sight is for UK orders only !!!!!
;)Not Shipping to US Sorry:(
Mr Vain
709
This is the Second person that has found an Ultra chip under his 775Dual-VSTA NB.
Originally Posted by Alchemist
Has your mobo got the PT880 Pro/Ultra or PT880 Ultra chipset in it?
Quote(Rad2) in another forum.
PT880 Ultra under the NB, I popped it off to see what it was.
Rev A1.03 bios 1.90.
StephenMSmith
50
I can 3rd it. I checked before installing the 775dual-vsta that I just got last week. "Ultra" label on top of chip.
Mr Vain
709
What does Cpuz read your Northbridge chip as?
StephenMSmith
50
It's say PT880 Pro. But I think Pro and Ultra are one in the same, except that they tested and verified that ones w/Ultra label run 1066mhz just fine. I think?
HX
8
Is there any possibilty to check if this mobo ( 775Dual-VSTA ) has Pro or Ultra chipset installed without removing Heatsink from Chipset ??? I dont wanna lose warranty :>
Mr Vain
709
Cpu-Z, Everest, HWiNFO32 etc.
I think even if you have the Ultra chip, that it will show as PT880 Pro on this motherboard as this is what Asrock has programmed.
Just read the post above yours by StephenMSmith , he?s got an Ultra that is read by CPU-z as a Pro.
:confused:
Mr Vain
709
I have just read elsewhere that you need the very latest CPU-z version to read the chipset properly.
Try it and let us know if it reads it as the Ultra?
Mr Vain
709
Here is a different spin for why Asrock discontinued the 775Dual-VSTA in favour of the 4CoreDual-VSTA from (atlr) in a different thread.
quote:
Originally posted by: Beachboy
Interesting but this link shows that the 775Dual-VSTA already supports the quad cores when updated to at least the 2.10 BIOS.
Perhaps it's just a name change to make things super clear?
That Asrock link now shows the 775Dual-VSTA does NOT support quad core. I think the reason the 775QuadCore-VSTA was creeated is the same reason that Dell updated the XPS 700 to 710. The quad core processor has hardware design requirements that the 775Dual-VSTA may lack.
Quote from this Dell blog
http://direct2dell.com/one2one/archive/2006/11/15/3573.aspx
"As most of you know, Intel's Core 2 Extreme QX 6700 Quad-core processor will ship soon. Several of you have asked if this new processor will work on your existing XPS 700 motherboard.
Here?s what our development team had to say. Based on Intel?s current design guidelines, the Intel Quad Core Extreme Processor should work on the XPS 700 motherboard. However, Intel revised the design guidelines for boards to be compatible with this quad core processor to decrease the signal impedance of the front side bus. This is different from the board specifications on the XPS 700. Also, Intel specifies that the Quad Core Extreme Processor needs 4 GTLREFs (GTLREF is reference voltage to the CPU front side bus to recognize signals as high or low for data coming to the bus) and the XPS 700 board has only two references. Intel?s revised design guidelines for the signal impedance change and the requirement for two additional GTLREFs to support its Quad Core processor caused Dell to make system-level board changes that have been implemented with the new XPS 710. With those changes, Intel?s new quad-core processors are fully supported on the XPS 710.
Here are the legal disclaimers:
Intel quad core processors may have stability/life expectancy issues when used on the XPS 700 because it lacks the required GTLREF support, or they may not work at all.
If you attempt to upgrade an XPS 700 with an Intel Quad Core Extreme Processor, we can?t guarantee that the Intel Quad Core Extreme Processor will work, nor will it provide support for quad core processor-related issues."
- quoted from from this Dell blog http://direct2dell.com/one2one/archive/2006/11/15/3573.aspx
Edited: 01/28/2007 at 08:13 PM by atlr
nyker96
5,630
Anyone who played with this board, does it overclock better than the original 775dual? Any data on this one?
Mr Vain
709
From what I have read around in different forums it?s about the same. I have not really seen any data comparisons between both mobos, except for the reviews at OCW.
Gary Key
866
I am getting slightly better overclocks, gone from around 300 to 315 stable.
Mr Vain
709
Gary are we likely to see a review on this motherboard here at Anandtech soon?
:p
Gary Key
866
:p
Yes, and it will be with a Quad Core.
lookin4dlz
688
Thanks for the modded bios link. I'll wait for Gary Key's review & if it's good, try this out. Bookmarked until then...
stewaw00
Originally posted by: stewaw00
FWIW I just bought a 775Dual-VSTA in the UK, not even put the thing in a case yet and I've popped the northbridge heatsink - there's a PT880 Ultra lurking under there. PCB Rev is G/A 1.02
CPU-Z 1.39 says VIA PT880 Pro Rev. 00
Anyone run CPU-Z on a 4CoreDual-VSTA?
