Anand's Conroe article up and running
StrangerGuy
8,443
124
One thing in the review that annoyed me is how "power hungry, poor performing, non-competitive garbage (sorry guys, it's the truth) that Intel has been shoving down our throats for the greater part of the past 5 years."
Did Anand forgot how the Athlon XPs got owned by Northwoods?
lopri
13,316
690
Our chips were the luck of the draw
If that's the case, the following comment in the review could be severely misleading.
Intel could easily release a 3.46GHz or 3.6GHz Core 2 processor tomorrow if they chose to
Edit: Gary.. Check your PM plz.
OcHungry
Banned
Jun 14, 2006
197
Originally posted by: Duvie
Seems pretty good.....
Gaming looks better but ofcourse AT used high res but turned off all AA and AF...so not comparable to other sites....
I see great ocing but nowhere do they list the temps they got...It maybe th efact they are running the Asus i975x mobo that is widely considered to be off 15-20 degrees....
I also learned something the X6800 is the only cpu with totally unlocked multis...can you say like the FX of AMD???
And I don?t get the overclocking part.
The article says he could overclock to 4ghz on air (w/ tuniq) and stable but w/ stock cooling he could overclock up to 3.4ghz stable. That is 600 MHz difference. Since when heatpipe can improve overclocking? Does he mean w/ stock cooling he could not post to windows from 3.4-4ghz? Improving cooling system will improve overclocking just a tad and during stress test. Another word, w/ A64, 3000 I could post to window @ 2.85 ghz w/ stock cooling but cant run test. If I improve the cooling I can post to window the same highest speed (2.85ghz) and probably run prime 1 minutes. But no matter what cooling I use I can not go higher than 2.85ghz. W/ LN2 I might be able to post to windows and take screenshot @ 3.2 ghz but that's it.
There is a consensus in the net that only a few first time released conroe could do 4ghz on air but not stable. 99.9% of the ES that the privileged acquired can only do that w/ LN2.
But Anad can do it w/ tuniq?
This is very important to notice and always remember when retail conroes are in hands of consumer, to see if Anand's statement holds.
And as you said- no temp. was mentioned, and no benchmarked conducted for overclocking.
I want to know how an overclock conroe holds against an overclocked A64 x2 3800, 4000, 4200, 4600, 4800, and 5000. Never mind FX, because I want to see price/performance of conroe vs lower end AMD.
I have seen video encoding of A64 directly reflecting the percentage of overclocking. This not the case w/ conroe. Another word if both A64 and conroe overclocked 20%, A64 shows 20% improvement(w/ little degree of adjustment), but conroe shows only 5 to 7% improvement. This tells me, that AMD's IMC plays a big part, and percetage of overclocking directly reflects percetage of improvement. Thus it could be possible to overclock A64 3800 x2 to 2.7ghz and beat a E6400 overclocked to same speed (if can). Most importantly use stock cooling (or better heatpipe for both) and let them run stress test for several hrs (prime95 for example) and see which one holds up.
Furthermore, Anandtech did not test any in raid (AFAIK) specially raid 5. We know U.S. Government turned down woodcrest because of raid5 problem. So it is imperative to know how conroe does in raid.
All and All, I am very disappointed w/ the way Anad presented the review and the way wording and describing conroe. Certainly it is not a "King" or an "Empire" to strike back. This sound like fanboysm. Anad should have known better.
I see the TG's red card photo, which clearly shows fanboysm. The red card means the player has committed a serious fault in soccer game comprised of 22 players. Has AMD committed such similar fault as that red carded player? AMD and Intel are 2 players, the soccer game has 22, what happens to 21 other players and what do they represent?
I am just trying to understand the symbolic meaning of the red card photo by TG, but does not make sense to me.
I am afraid to say, that I am suspecting Intel spend a whole lot of money for this conroe publicity, but I am one that will not buy into it.
Gary Key
866
Originally posted by: DLeRium
Ughhh I don't like how we don't have an E6400 in here. You see a huge gap between the 6600 and 6300. I think the 6400 would fit right in between the 4600 and 5000+. Sub $300 chip killing an X2 4600+? Sounds good to me.
We are still trying to get E6400 review samples, it is a rare bird at this time, almost exotic in nature. :D I personally think for the vast majority of users this will be the CPU to have if you are not into becoming a benchmark professional and want to have a great "under 1K" Intel system.
Gary Key
866
Originally posted by: lopri
I honestly thought sometimes I was seeing Mr. Kyle's (who I believe to be so much lacking when it comes to intelligence, compared to Anand) mirror image while reading this review, which was very surprising. I'm positive that the numbers from both sites (AT and HardOCP) are accurate but in this article, Anand's trying to influence readers with his own evaluation. In the past Anand usually steps back abit off something controvertial and throw some wits here and there, or cast his opinions cautiously. But in this review, he makes so many generalized claims, some of which are quite risky, IMO. For example,
At default voltage the X6800 reached a stable 3.6GHz (13 x277). This is a 23% overclock from the stock 2.93GHz speed at stock voltage. It is also an important overclocking result, since it implies Intel could easily release a 3.46GHz or 3.6GHz Core 2 processor tomorrow if they chose to.
He even goes on to imply the Extreme Edition might actually be worth $1K.
AnandTech never recommends the fastest chip you can buy as a good value choice, but X6800 does bring some advantages to the table. It is the only Conroe that is completely unlocked. This allows settings like 266(stock FSB)x15 for 4.0GHz, settings that keep other components in the system at stock speed. This can only be achieved with the X6800 - other Core 2 Duo chips are hard-locked - and for some that feature will justify buying an X6800 at $999.
While this review is by far my favorite Core 2 Duo review on the net, I'm somewhat curious with the change of Anand's style.
It was really late when we added in the Overclocking page, too much coffee leads to a slight edginess in the writing style. :laugh: We will have more on overclocking in the very near future once the new retail chips arrive. Stepping 5 was going to be the release when we received our kits, now at stepping 6 and awaiting an answer as to the change now instead of in the fall as planned.
Dadofamunky
2,184
Thanks for the feedback and the updates on an excellent review. Some people, I guess, just want a perfect input on all aspects of their interests all the time, which is obviously impossible. I thought Anand's piece was one of the better ones I've ever seen on this site. His writing style has gotten much clearer and grammatically accurate. Kudos.
kknd1967
214
It would be good to see AT do some benchmark on the 32/64-bit performance difference issue
Mr Bob
1,757
12
Wow, I didn't expect to see a benchmark where Intel blows AMD away in both encoding and gaming.
Are these really going to be less expensive than an AMD with similar performance?
secretanchitman
9,353
23
that was a nice article by anand. glad to see him writing again.
bottom line, if you are an overclocker, get the E6600. if you want the best value system under $1000, get an E6400. want the cheapest core 2 duo? E6300. want a cpu with an unlocked multipler? X6800. want a cpu that will beat the amd athlon 64 FX-62 without overclock in 100% of benchmarks it goes against? E6700 is perfect.
for me...E6600 is MINE!
lopri
13,316
690
It doesn't seem like Anand wrote the article, eh? ;)
Sable
1,130
105
Core 2 Duo E6600 2.4GHz $316.00 can match the AMD Ahtlon FX-62 2.8GHz $1,045.00 in the majority of tests.
This is on present prices, AMD have still to annouce their price drops though.
TanisHalfElven
3,512
Originally posted by: akshayt
I would prefer an article where stuff which a normal person has is used.
A64 - X2 4800 - FX 62 on Geforce 7300GT - Radeon 1900XTX crossfire
so normall ppl have x1900xtx crossfire. ?
and no one with a 7300gt will buy a fx-62 if they're gaming.
anyway its nice to see intell wit ha fast proc finally. i just really hoppe amd does not go under. it would suck to have intell slow the current pace of tech advance.
twjr
627
207
Windows 98 has no support for multi core cpus.
Friend tried installing it on a comp with an x2 and it stuffed up and he lost everything.
arctic388
66
so if i remember right one board has 16 pipelines and if i want to use just one nVidia card that would be perfect right ?
DrMrLordX
23,060
13,163
You could run a Win98 virtual machine under XP pretty easily. VT is good for stuff like that.
xtknight
12,974
Originally posted by: AkumaX
i dont think a64 works with win98, so i doubt it would work w/ core2duo
The Athlon 64 (32-bit compatible processor) should be able to run Windows 98 but only one core will be detected in a SMP/dual-core configuration. I believe SMP-aware programs like Photoshop are able to utilize the second core regardless of Windows 98 but don't quote me on that. Of course I am talking strictly about CPU compatibility. You will need the proper chipset drivers, etc.
Who wants to run Win98 though? Even XP is better than that. ;)
