angrsquirrel
- Apr 14, 2005
- 6
- 0
- 0
I have another problem. I am running the above motherboard. If I try to up the fsb to anything higher than 230 I start having my system locking up in games. I am able to get the thing to overclock at 10x235 = 2.35 ghz. What is happening is that it locks for like 20 seconds and then the game starts running again. I see it happenign alot in stronghold 2. The higher I bump the FSB, the more I get these random lockups. At 10x250 it's like every few minutes that the lockups occur and they last longer.
I have a GF4 6600 gt video card,
Here are my specs from Sandra:
Mainboard
Manufacturer : Soltek
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : K8T800pro
System BIOS : 01/28/2005-K8T800pro-6A7L1SN9C-00
Chipset : VIA K8T800 Pro
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 16GB
Bank0/1 - A0 : None None None None DIMM 512MB/64
Bank2/3 - A1 : None None None None DIMM 512MB/64
Bank4/5 - A2 : Empty
Bank6/7 - A3 : Empty
Chipset 1
Model : VIA Technologies Inc K8T880Pro CPU to PCI Bridge
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
Version : 1.02
Front Side Bus Speed : 2x 940MHz (1880MHz data rate)
In/Out Width : 16-bit / 16-bit
Chipset 1 Hub Interface
Type : V-Link
In/Out Width : 4-bit / 4-bit
Multiplier : 1/1x
IO Queue Depth : 9 request(s)
Logical/Chipset 1 Memory Banks
Power Save Mode : No
Fixed Hole Present : No
Chipset 2
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Version : 1.02
Maximum FSB Speed / Max Memory Speed : 2x 1000MHz / 2x 200MHz
IO Queue Depth : 8 request(s)
Chipset 2 Hub Interface
Type : HyperTransport
Version : 1.02
Logical/Chipset 2 Memory Banks
Bank 0 : 512MB DDR-SDRAM 3.0-3-3-3 2CMD
Bank 1 : 512MB DDR-SDRAM 3.0-3-3-3 2CMD
Channels : 1
Bank Interleave : 2-way
Speed : 2x 235MHz (470MHz data rate)
Multiplier : 1/10x
Width : 128-bit
Refresh Rate : 5.00µs
APIC 1
Version : 0.03
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module 1
Manufacturer : Micron
Model : 16VDDT6464AG-40BC4
Serial Number : 0C07E964
Type : 512MB DDR-SDRAM
Technology : 16x(32Mx8)
Speed : PC3200U 3.0-3-3-8
Version : 1.1
Date of Manufacture : Wednesday, September 17, 2003
Set Timing @ 200MHz : 3.0-3-3-8
Set Timing @ 167MHz : 2.5-3-3-7
Set Timing @ 133MHz : 2.0-2-2-5
Memory Module 2
Serial Number : 0C07E966
Version : 1.1
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Environment Monitor 2
Model : NS LM83
Version : 2.01
Temperature Sensor(s)
Board Temperature : 39.0°C / 102.2°F
CPU Temperature : 34.0°C / 93.2°F td
Power / Aux Temperature : 25.0°C / 77.0°F
HD / Aux Temperature : 49.0°C / 120.2°F td
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 2344rpm
Voltage Sensor(s)
CPU Voltage : 1.50V
Aux Voltage : 2.75V
+3.3V Voltage : 3.22V
+5V Voltage : 4.92V
+12V Voltage : 11.54V
-12V Voltage : -11.87V
-5V Voltage : -5.06V
Standby Voltage : 4.92V
Battery Voltage : 4.08V
AGP Bus(es) on Hub 1
Version : 3.00
Speed : 8x
Fast-Writes Enabled : Yes
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (1/1x PCIClk)
LPC Hub Controller 1
Model : VIA Technologies Inc VT8237 PCI to ISA Bridge
ACPI Power Management Enabled : Yes
Multiplier : 1/4x
DMA Multiplier : 1/2x
USB Controller 1
Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : VIA Technologies Inc VT6202 USB 2.0 Enhanced Host Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
FireWire/1394 Controller 1
Model : VIA Technologies Inc VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Version : 1.10
Interface : OHCI
Enhanced Support : No
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : VIA VT823x SMBus
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
PCI0 (1h) : PCI 32-bit +5V PME Full-Length Available (VIA Technologies Inc Apollo K8HTB CPU to AGP 2.0/3.0 Bridge)
PCI1 (2h) : PCI 32-bit +5V PME Full-Length Available
PCI2 (3h) : PCI 32-bit +5V PME Full-Length Used
PCI3 (4h) : PCI 32-bit +5V PME Full-Length Used
AGP (8h) : AGP 32-bit +5V Full-Length Used (Pine Technology Ltd GeForce 6600 GT)
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - PS/2 / PS/2
PS/2 Mouse : Mouse - PS/2 / PS/2
USB0 : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed.
Warning 2542 : Memory bus speed exceeds Chipset rated speed. Reduce FSB/memory multiplier.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
If there's anything else you guys need, let me know! Thanks!!!!!
Mainboard
MPS Version : 1.40
Model : K8T800pro
Chipset 1
Version : 1.02
Type : V-Link
Multiplier : 1/1x
Chipset 2
Version : 1.02
Version : 1.02
Channels : 1
Multiplier : 1/10x
Width : 128-bit
APIC 1
Version : 0.03
Multiplier : 1/2x
Memory Module 1
Version : 1.1
Memory Module 2
Version : 1.1
Model : NS LM83
Version : 2.01
Cooling Device(s)
Voltage Sensor(s)
CPU Voltage : 1.50V
Aux Voltage : 2.75V
+5V Voltage : 4.92V
Version : 3.00
Speed : 8x
Version : 2.10
Multiplier : 1/4x
USB Controller 1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Version : 2.00
Interface : EHCI
Channels : 8
Version : 1.10
Interface : OHCI
Channels : 64
Speed : 400MHz
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
Port Connector
Performance Tips
