Still problem with Dual Channel !
I never got dual channel on my K8TPro-939 to work with my old 2x512MB Elixir PC3200 and one stick went dead when trying so I only had 1x512 left. Quite handicapping.
So I ordered 2x512MB A-Data PC4800 but they seem to take forever to arrive so I cancelled the order and bought 2x512MB TwinMos Twister Pro PC3200 2-2-2-5 TCCD/Brainpower instead. They where also cheaper and still it's the same TCCD and PCB.
But they won't boot in dual channel either, nothing but the dreaded C1 whatever I do !
Could someone please point me in the direction where I might be doing wrong ? Or do I have a faulty cpu or a faulty motherboard ? I know my PSU is weak(Q-Tec 550W 16A 12V 20A peak 12V) but 2 dimms in single channel do work, so why isn't dual channel working ? Is the Soltek bios still less than perfect in regard to memory compability ? Also, if I set command rate to 1T the board won't boot in songle channel either, C1 again. Or is the cpu memory controller defect ? At least the cpu clocks rather good, 2.5GHz was NO problem and no heat.
So now I run my 2x512MB 217MHz fsb/mem 1:1 at the moment 2.4GHz/433mem 2.5-3-3-8 at 2T which isn't exactly fast, barely faster than my 1x512MB of Elixir at 2.5GHzz/354mem 2.5-3-3-7 at 1T. At least I have 1GB again, which is nice as 512MB is way too little today, but if performance isn't faster than this I can as well start using the Elixir stick for 1.5GB as I wont hold anything back performancewise anyway. The board won't boot at high performance settings, that's it.
I might still get higher in frequency though, but that seems not so fun in singel channel and 2T.
What is it whith this board and dual channel and 1T ? I would really aprecciate an educated answer from Lydia or elsewhere, or do I have to go and get a Nforce 3 250 Ultra-board to get dual channel ?
The least troublesome would be if this is an bios-issue: bios compability or myself setting it up awkward, after that I guess getting a new PSU would be the next less troublesome as I know my PSU isn't exactly good, but what if it isn't the PSU either and I go and get an expensive PSU in vain ?
Come on, use your brains, and I will be very very happy to get some good input
