A64 OCs (Air) Poll
crossphyr
66
not to break ur bubble dude.. but just because ppl say they are at 2.6 doesnt mean they are... im sure there are plenty of liars... you shouldve asked for prime95 ss's..
Duvie
16,215
YOu know what I am in a bad mood right now...so..STFU!!! I dont care.....I expect ppl to be honest, I have no way to verify anything....
Break my bubble??? LOL....I break your arse...I have no bubble...PUNK!!!!
Avalon
7,571
178
Duvie, my sempron is of the 90nm process. It's a Palermo core, which is basically a 256KB L2 cache winchester with SOI. Can I not vote? :p
Duvie
16,215
Sorry....I say we start a new one for you and the semprons since they appear to be a mighty ocer as well and a heck of a bargain chip....
arnosmith
51
Back in the old days, when people used horses instead of cars, and washed themself with a bucked of water instead of of taking a shower, I aircooled my 3200+ and used 265x10 daily. When I tried to impress people, I would pull it all the way to 278x10 :) Wouldn't bench much at those speeds though...
One thing I'm quite irritated about is that I can't seem to get the damn Prime95 to work! Even below stock speeds on everything I have got of hardware, it stops after a few minutes... Anyone else with the same problem?
lotus503
6,502
Originally posted by: Duvie
Originally posted by: teutonicknight
IDLE: 30c
LOAD: 43c
3200 @ 3.5 GHz
No water cooling or vapo/prometia.....I SAID AIR!!!!
Man I will just flat out call bullshit. A water rig isnt going 3.5 h and sub zero cooling would have the temps lower than what he shows
Markfw
May 16, 2002
27,287
16,123
one comment I have about OC's. My two run at 2.3 or even 2.4 and even for hours. But neither can run for 3-5 days straight using F@H and not have early unit end's at more than 2.2 (one is a 3200, one is a 3000) What I really wonder is if those running 2.6 or better can run F@H for 5 days and no early unit end's !!!!
Amaroque
2,178
Most people don't care about 24/7 stability. I run various DC programs, so 24/7 stability matters to me very much.
I can clock the CPU's much higher then what I normally run my machines at. Reason being is that I don't want to have to baby the computers while running any 24/7 program.
perillo34
287
2.57ghz 0504 Winnie 300+ retail from Chiefvalue. Will do 2.6+ but I my memory drops below 200mhz.
Elfear
7,165
824
My old 3500+ did 2.60 stable on a Neo2. I think the voltage was somewhere betweeen 1.5-1.55V.
My 3000+ is Prime and memtest stable at 2.595GHz, 288x9, 1.50V.
Duvie
16,215
I did 7 days at least with no end units at 2640ghz.....I haven't ran it at 2665ghz but I do have .04v more of vcore and the HTT is lower...I think it would do it just fine....
I have 48hours stable at 2.64ghz with prime95 and 62hours at 2.61ghz....
billwinkle
74
I now have my system at 300x9. I don't want to skew the poll. yesterday I added my system at 2.6 gig. I am now running at 2.7
memory is running at 270fsb 2.5 3 3 6 1t
htt 3
motherboard temp 30c cpu 34c
my componets
CPU: AMD64 (WINCHESTER) 3000+@2.70ghz 9x300fsb (1.54v)
htt: 3
MB: MSI K8N Neo4 platinum sli
HD:2x 200GB WD SATA RAID 0
HD:1X 200GB WD SATA
HD:1X 200GB WD IDE
RAM: 2X512 OCZ High Performance DDR400 revision 3
POWER: ENREMAX 480 NOISETAKER
DVD: NEC3500A
VIDEO: GIGABYTE 6600GT (single for now)
cpu cooling ZALMAN 7000CU.
here is a link to picks to prove.
screenshot
thriemus
215
2640 running 11 x 240 @ 1.5 in bios gives 1.52 in Asus PC Probe & Sandra 2005 on air (See Below) 29 Idle, 43 Under full load.
I can get 2699 running 11 x 245 @ 1.5, but the system runs "sluggish", stable albeit, but sluggish.
Insomniak
Banned
Sep 11, 2003
4,836
Just walked up to 2.4Ghz last night.
A64 3000+ Winchester @2411Mhz (according to CPU-Z)
3xHTT
300x8
1.5v
29C idle, 43C full load
Stepping 0, DH8-D0 revision
Stock Cooling
Mushkin Basic Green PC3200 @ DDR400
2x512MB
1T, 2.5-3-3-8
3:2 divider
Primed stable for 12 hours overnight. Will be trying for 2.5 - 2.6Ghz a month or two down the line.
Duvie
16,215
90+ now and where is that punk-biatch sentinent or whatever his name was...said only 2% of winchesters get to 2.6ghz....Got 30+% now and even if some are not all stable I dont think it is 94% of them.....
Avalon
7,571
178
Actually, that's a very good idea, Duvie. It'll be nice to know how SOI and 90nm is doing for the socket 754. It should give overclockers more incentive to dive in. Will you do the honors?
Duvie
16,215
The honor is all yours...I think that way you know about this stuff and can try to put conditions on who you want to particpate in the poll....
Clock for the clock the sempron is a beast...just look past those damn pr rating BS....a 2.5ghz sempron appears to run close to a 2.5ghz A64 in cpu intensive apps...the only plavce it may lose and lose only slightly will be in apps that can take advanatge of 512 or even 1mb of L2 cache and the 3-5% dual channle can give in just the right apps....
Insomniak
Banned
Sep 11, 2003
4,836
Well it should be - all it is is Athlon XP renamed.
